Bosch Nexxt  700 Series WFMC6401UC Front Load Washer
Problem for Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
I only have hot water going into the machine on all the settings.
By dolores_arch on Jul 28, 2009
I bought my machine 2 months ago & its been like that since I bought it. I turned off both hot & cold water at the tap & turned the cold back on & you can hear the machine but no water. Took off the hoses & checked to make sure not clogged. These are the original hoses & it appears that the flap to get cold water into the machine might be stuck in the closed position.
Best Solution
posted on Jul 28, 2009
Very Helpful)
VtToolMan
Rank: Guru
Rating: 97%, 599 votes
You need to verify that the cold water is actually flowing through the cold/hot water shut off valve at the wall/floor first. If you are getting water flow at the supply side of the house, it is likely that the washing machine has a defective water inlet valve.
It is possible that it is a very simple problem to fix, such as a wiring plug not connected to the cold water inlet valve (solinoid), but since this is a new machine, you should have the issue handled with the warranty service. If this was a used machine you purchased, then by all means do some investigation to see if you can locate the issue.
Start with the basics by making sure the water is actually getting through the house supply valve and through the washer hoses. By the way, you should change supply hoses whenever you get a new machine, since a broken hose can easily cause extensive damage should it fail. Most manufacturers are now recommending that owners replace their washer supply hoses every 5 years.
OK, if the water is flowing throught the valve and hose, and when you reconnect the hose to the washer and turn it on and you aren't getting any water into the machine, if you hear a humming sound, then the valve is likely getting power but could be defective or has failed. There is no "flap" only a solinoid that cycles a piston back and forth to either let let water flow into the machine or shut the water supply off. Other than that, there shouldn't be anything else preventing the water from getting into the tub.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 05, 2009
Not Rated)
SouthrnStyle
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with the cold water not coming through. I took the cold hose off, pointed it out the window, turned on the cold faucet and it had great pressure. So, I took the filter out of the fitting in the back of the washer and checked it. It looked just fine. I then took a flashlight and looked into the opening of the cold water fitting and I could see the opening in the back was closed for the exception of about a 1/4" (I assumed the was valve stuck) So like all Southern Ladies, if it doesn't move and it should...grabbed the WD-40. I unplugged the washer and then I sprayed a small amount into the fitting, took a small knife and tried to move the valve open. It didn't appear to be moving but decided to put everything back together and wha-lah...we have running hot and COLD water.....next is a duct tape fix...now where did I put my silver cure-all????
Was this helpful?
Yes
No
Popular Solutions for Bosch Nexxt 700 Series
Questions and Unsolved Problems for Bosch Nexxt 700 Series
Do you recommend Bosch Nexxt 700 Series WFMC6401UC Front Load Washer?
Answer
Answer
how do get the front off of a bosch nexxt dryer?I have taken all the screws that i can find out on... (More)
Answer
My machine is leaking from the left bottom..just started today. Not sure what the problem... (More)
Answer
Bosch washing machine WAE 24162 washes continuously and has to be advanced manually via the buttons... (More)
Answer
I need something to make my old towels soft, i have tried loads of fabric softners, even vinegar but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Nexxt 700 Series...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14881
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
