Question about Whirlpool Duet GHW9150P Front Load Washer
CONTROL LIGHT WILL NOT GO OUT - Whirlpool Duet GHW9150P Front Load Washer
  • 5,911 Answers
It sounds like you have a Control Lock issue. The following link explains how to correct a Control Lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these procedures do not correct the error, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
Posted on Jul 28, 2009
Stabilizer traction control light is on, and lost cruise control
Cruise control will always disable itself when any CEL light is present, so that's normal. The Stabilitrak light problem is a known common problem with these. Your steering wheel position sensor needs to be replaced. Mine does it every morning IF my steering wheel wasn't put into a straight position when I parked it. Straighten the tires, turn the ignition off and restart. Light will go out.
Apr 02, 2016 | 2008 GMC Envoy
Why does my ABS light stays on and sometimes i get a vibration in the brake petal causing my 2002 Cadillac escalade not wanting to stop?
Sounds like a fault with the Antilock Braking System. The vibration in the pedal is the ABS working. With your foot on the brake pedal, it releases and re-applies the brakes to stop a skid from the wheels locking up. You need professional service for brakes.
Seems to be a known issue on all Cadillac and requires the ABS module to be replaced.
ABS Light Due to ABS Control Module Failure : Cadillac ...
repairpal.com > Problems > Cadillac > DeVille Cadillac DeVille ABS Light Due to ABS Control Module Failure. This is a verified problem based on 126 reports. Learn more about this problem, when it occurs ...
repairpal.com > Problems > Cadillac > Seville STS Traction control and ABS lights stay on dash. This is due to ecbtm Module gone bad. replace Module and this should fix the problem. You can go by the VIN and ...
repairpal.com > Problems > Cadillac > DeVille DTS ABS Light Due to Control Module Failure on Cadillac DeVille DTS. The anti-lock ... ABS and Traction control light stays on. ... abs light to abs control stay on.
repairpal.com > Problems > Cadillac > Seville SLS ABS Light Due to Control Module Failure on Cadillac Seville SLS. The anti-lock brake ... SLS135,000Jumsee. Abs and traction lights stay on when started.
Jan 12, 2016 | Cadillac Cars & Trucks
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
Why is my check engine light and VSC light on
The check engine light is drivability which affects emission and to protect the catalytic,when this light comes on VSC is disabled.This helps protect the catalytic.
Apr 03, 2012 | 2009 Lexus ES 350
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
The cruise control light flashes and can not be activated
CHECK TO SEE IF BRAKE LIGHT WORKING.BECAUSE BRAKE LIGHT SWITCH DEACTIVATE CRUISE CONTROL WHEN BRAKES APPLIED.MOST TIME IF YOU HAVE CRUISE CONTROL PROBLEMS FAULTY BRAKE LIGHT WILL CAUSE CRUISE CONTROL PROBLEMS.
Dec 08, 2010 | 2008 Subaru Outback
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
What does the VSC light on the dash mean
VSC means Vehicle Stability Control. Take the car for a scan to ease your mind.
May 20, 2009 | 2004 Toyota Solara
Whirlpool Duet GHW9150P Front Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
