Question about Panasonic DMR-E60 DVD Recorder
All discs are read as 'no disc' when i try to play them on dmr_E60
  • 158 Answers
Replace the laser
Posted on Jul 31, 2009
How to play region 1 dvd's on dmr-ez27
http://service.us.panasonic.com/OPERMANPDF/DMREZ27-MUL.pdf
this plays region 1 or all regions disc.....recording format can be different, may not play some discs...read this.......good success, meder's tv service
Nov 28, 2012 | Panasonic DMREZ27 DVD Recorder
Panasonic dvd recorder dmr-es15 cannot read disk
see this cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
finally the OPU, optical pick up unit contain lasser beam, is not reading the TOC, can be defective.see the diagram
God bless you
Jul 16, 2012 | Panasonic Televison & Video
My panasonic dmr-e60 shows 'no read' every time I try to play a dvd. How can this problem be solved?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD. If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Nov 17, 2011 | Televison & Video
Dvd player not recognising any discs
Did You Try Taking off The Cover And Cleaning The lens With Rubbing ahocal
Jul 12, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Mar 02, 2008 | Panasonic DMR-E55 DVD Recorder
Permanent Disc Protection
Hi, UnFormat Problem 1. Try Panasonic DVD-RAM, format that on the recorder, donot finalize OR 2. Try this http://www.videohelp.com/forum/archive/repair-guide-for-panasonics-dmr-e60-gh-quot-unformat-quot-error-t299504.html There is a jpg image on the above URL for guidance Hope your problem vanishes :) Moulee mbchandru@gmail.com
Aug 03, 2007 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E60 DVD Recorder Logo
244 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
