SOURCE: PLU and department Casio TE 2000
Hi.
Your machine comes standard with 24 department buttons on the keyboard, and PLUs by memory location. It is hard to explain simply, but the basic idea is that a department is designed as a category key, and a PLU (Price Look Up) is designed for specific items with an attached price. As your machine has a pricing function for departments, you really don't need PLUs on such a simple machine.
What I'm really saying is the keyboard has departments on it which can be set with a name and price so that they can be one touch buttons to bring up name and price with a touch, or you can have them open price (where an item has no preset price, so you type the price each time). If you need a lot more than 24 item buttons, you will have to do the rest by code numbers, as this is only a basic machine.
Just let me know how many items you wish to enter into it, and I'll tell you how to program it.
The tables you are referring to with a+b=c etc. are the machine features, or system programming. These are the important settings that tell the machine what things to print, how the function keys will operate, security settings etc. These are mainly for us dealers, as they are written in tech speak as you can see. I don't recommend changing any of them unless you need to, as you can get into a mess. If you tell me anything that doesn't work how you would like, I can help you to set the machine features where necessary.
SOURCE: I cannot change the price for an item on CASIO TE-2400 register
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
SOURCE: date setting for cash register casio TE-100
Turn key to program mode.
Type date as YYMMDD
Press X/TIME (maybe labelled X/ DATE TIME)
Press CLEAR
For those of you needing a Casio TE-100 manual, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Testimonial: "My problem might be very simple, but, the response is superb.. I'm glad I was asking to the right place.. Thank you very much.."
