Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
No power, I checked fuse box,it has not been tripped where do I start ?
  • 4 Answers
Check your wirering to make sure it hasn't been cut or chewed on by something
Posted on Jul 28, 2009
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
Apr 15, 2017 | Heating & Cooling
Tip
Wont start or dead dishwasher, no lights, no power, thermal fuse
If you have a dishwasher that is not doing anything, the first thing to check is the incoming power. Make sure the circuit breaker is on and not tripped.
Another place to loose power to the dishwasher is under the sink if it is plugged in to an outlet. It could have come disconnected.
The third place to look is a wall switch. If you have a switch that does not operate a light in the kitchen it may be connected to the dishwasher power source.
If all of these are okay the next place to check is the junction box of the dishwasher. To check here you will want to turn the breaker off first or remove power from the cord before taking panels off. By removing the kick plate or lower panel on the dishwasher you can access the electrical junction box. Many times the wire connectors were not properly installed in this box and over a period of time the connection is lost. This connection should be made by a professional.
If we have power to the dishwasher a common component to fail on many brand such as Whirlpool, KitchenAid, Kenmore, Maytag is the thermal fuse. This device is a two wire heat activated fuse that if tripped will disable the dishwasher. This thermal fuse is attached to the control circuit board that is usually in the console in the upper portion of the door. It can be checked with an ohmmeter just like a regular fuse. When replacing this fuse it may come as a kit with wire connectors, be sure to use all of the parts in the kit. The fuse often will blow due to a loose wire connection on or near the fuse, that is why new connectors are supplied.
A sample image of a typical thermal fuse kit is shown below.
on May 04, 2010 | Dishwashers
My dishwasher wont start after the power outage. all the lights are working fuse box is checked also.
please follow this steps and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Control Electronic
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 30, 2013 | Kenmore 24 in. 15689 Built-in Dishwasher
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
Vtd65 tripping fuse box
I am not familiar with that model.
Nov 14, 2011 | Dryers
Power door locks do not work unless the ignition switch is on, radio and dome lights also do not work.
look for another fuse box in or under dash. still sounds like you have a blown fuse. look in owners manual for all fuse box locations,including underhood electrial center. good luck.
Oct 29, 2011 | Cars & Trucks
The dryer does not emit any heat.
check your fuse box and make sure you don't have a blown fuse, check the breakers and trip back and forth to be sure it's not partially tripped. Verify power at dryer outlet with a multi-meter, L1 and L2.
Feb 18, 2011 | Samsung DV218AEW Electric Dryer
Unit "clicks" when turned on, but will not start up.
The click you hear is the contactor getting pulled in whe there is a call for cooling. There are a couple of things you can check before calling someone.
1. Make sure you are getting 220v power to the unit. (breaker tripped, fuses in disconnect box outside).
If you have a volt meter, you can just check the power at the box before and after the fuses, if any at all.
2. If you are getting power, you can check the capacitor. The capacitor is a round or oval object with 2 or more wires going to it in the units electrical compartment. A visual check can be done by seeing if the top of the capacitor is bubbled up at all, but sometimes there are no visual indications and will have to be checked with a multi-meter that reads micro-farads (mfds). Capacitors are a common cause of a unit not powering on and pretty cheap to fix yourself, you can pick them up at a local A/C supply store.
If you have a tripped breaker or a blown fuse and the breaker trips again right after or a fuse blows again, you might have a shorted compressor and will have to be looked at by a technician. Hope this points you in the right direction!
Aug 17, 2010 | Goodman CKL36AR36 Air Conditioner
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
174 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
