Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I think the timer is broken on my Whirlpool Ultimate Care II
The washer fills up with water at the start of the cycle and agitates for a few minutes, then just stops. I think either the timer is broken. Or maybe the washer "thinks" the door is open, because it seems to be stopping at the same point in the cycle it would normally stop if I had the door open.
If it's the timer, where can I get a new one? And how would I replace it?
I currently have a washer full of water that won't drain (I removed the clothes). Is there any way to get it to drain manually?
  • 44 Answers
Hi,to drain manually----get a plastic basin [the square type] and take the outlet hose and lower it gently below the water level in the m/c and let the water flow into the basin.dump the water into sink. repeat procedure until water is gone from m/c good luck
Posted on Jul 30, 2009
  • Whirlpool Master
  • 1,525 Answers
Hell it sounds like the programmer may be the trouble
shaun
Posted on Jul 29, 2009
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't cycle through...
The cycle timer may be defective and will need replaced. Hope this was helpful.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
374 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
