I have a Wurlitzer CD 1015 one more time jukebox playing fine on free play. Moved jukebox and all it does now is the digital lights two of the zero's blink back and forth. The mechanism that locks basket in place will not lock. It just turns freely as if putting cd's on it.
SOURCE: My jukebox doesn't play
DOCTOR-FIXCAN MAKE A COPY FROM MY ORIGINAL. MOST LIKELY YOUR PROBLEM IS THE LIGHT THAT COUNTS AS EACH CD PASSES. LOOK BETWEEN CD CAROUSEL, AND CD GRIPPER ARM. A CD MAY HAVE HIT THE METAL LEAVER THAT THE LAMP,
IS ATTACHED TO. YOU HAVE TO GET DOWN 0N IT WITH A MIRROR TO SEE THE LAMP, AND SEE IF THE METAL LEAVER IS NOT BENT. FOR COPY OF WURLITZER MANUAL, A CD RECORD PROBABLY HIT THE LAMP. 636 2273300. NAME IS SEYMOUR LEVITT COMPANY NAME IN-HOME JUKEBOX REPAIR. [email protected] THIS IS A COMMON REPAIR PROBLEM. GOOD LUCK.
SOURCE: My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
SOURCE: Jukebox CD Player: wurlitzer 1015 cd player take about 5 minutes befo...
Faulty CD player or faulty control pcb under the laser unit. That's assuming it is not spinning at all until ages after it has put the Cd down.
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
email me at [email protected] for the manual and service programme
