Back to:
Tags:
T-Mobile Sidekick II
My tmobile sidekick slide (by 14 users)
posted by jeee on Nov 22, 2007
my problem is i cant get ringtones on my phone when i bluetooth from others phone it fails i cant get them off the web for some reasons so i need instructions on how to put ringtones on my phone using the usb cable
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by Guest, posted on Aug 21, 2008
yup same exact thing. i'm think of just trading my slide to a different phone already. freck i hate having to research and waste my time getting the bluetooth and ringtones on my memory card to work. ugh.
Comment by Guest, posted on Aug 06, 2008
everything
Comment by lilfredd, posted on Jun 27, 2008
how to put ringtones with a usb cable ona side kick slide
Comment by Guest, posted on Jun 27, 2008
how to put ringtones wiht a usb cable
Comment by Guest, posted on Jun 17, 2008
conect my bluetooth with my sidekick slide
Best Solution
posted on Feb 23, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The reason T-Mobile locked bluetooth and the sidekick ringtones is not because of hackers. Why do you think they didn't put a recording app on the phone? They made it this way because if you are not able to purchase ringtones from other sites, make them yourself, send them via bluetooth, or record them then YOU WILL HAVE TO BUY THEM FROM t-mobile. It is because T-Mobile is a greedy company and that's how it is, I have used them since the SK1, you can't a ringtone on your sidekick except from the catalog if you have T-Mobile. If you are on a different network outside of the US with the sidekick that is a different story.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my tmobile sidekick slide:
I don't want to Accept this solution
Solution #2
posted on Dec 29, 2007
Helpful (85)
GrinningFool
Rank:Guru Guru
Rating: 91%, 261 votes
You can only get ringtones from the t-mobile catalog. You can put mp3 on your slide but not as ringtones.
Comment by GrinningFool, posted on Dec 31, 2007
surenony- Do you have a SD card in your phone? To move files over it has to be onto a sd card.
Thank You!
Solution #3
posted on Jan 23, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
I had just asked customer service, and they actually put a lock on the sidekicks and will begin to lock new phones to where you can only use bluetooth for the earpiece and calls.
They had problems with hackers and so they got rid of the capabilities and locked bluetooth.
Thank You!
Solution #4
posted on Nov 14, 2008
Not Rated (0)
cpFrmTheNA
Rating: 0%, 0 votes
Ok have ne one of u guy put a theme on a side kick??! As you know once you plug you're USB cable in ur comp. states that a mass storage drive has appear! ( well if it dont go to my comp. and look for drive G, or a mass) open that up and make a NEW folder for themes call it....... themes... for ringtones type ...... ringtones.! that should get you going on to better questions! now to find free ringtones compatiable with the side kick is up to you! good luck!
~cp~
Thank You!
Solution #5
posted on Sep 08, 2008
Not Rated (0)
kia69
Rating: 0%, 0 votes
I tried to use mobango.com and i still couln't get ringtones
Thank You!
Solution #6
posted on Jul 07, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
actually can use mobango.com
Thank You!
Solution #7
posted on Jun 26, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i had the exact same problem and im seriously considering getting rid of my slide. its rediculous!
Thank You!
Solution #8
posted on Jun 22, 2008
Not Rated (0)
loccsta
Rating: 0%, 0 votes
welll i gotta bluetooth earpiece i jusz wanna knoe if i can hook it up or not cuz this phone iz stupid im finna sell it fa $5 on ebay.. sumbody uh buy it
Thank You!
Solution #9
posted on Jun 19, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
this is gay
Thank You!
Solution #10
posted on Apr 08, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
well thats just mean.
Thank You!
Can you Help with these PDAs problems?
deseo tener o conocer como manejar o el manual del...
whenever i plug the phone in to charge the screen...
My sidekick says flashes "sim?" where the signal...
my kick 2 wont turn on but i had it on a few minutes ago
i can not get into my phone i forgot the 3digit privacy...
13 Other Users Have The Same Problem - Continued
Comment by jesus713, posted on Jun 06, 2008
My bluetooth for sidekick slide wont work
It always says the connection has failed
And i cant get my bluetooth for my sidekick slide to work u think u noe how 2 do it?
Comment by Guest, posted on Jun 06, 2008
How can i make it work so i can get the ringtones thay are sending me
It says the conncetion for bluetooth has failed.
Comment by Britniegh, posted on May 21, 2008
I need instructions on how to put ringtones on my phone using the usb cable
Comment by Guest, posted on May 20, 2008
can't find ringtones
Comment by Dre 15, posted on May 13, 2008
can't get ringtones on my sidekick slide when i bluetooth it does not work.
Comment by Guest, posted on May 08, 2008
How do u transfer mp3 from your sd card to make them ringtones help....
Comment by surenony, posted on Dec 30, 2007
i can not use my usb cable, the pc did not reconized the device
Comment by Guest, posted on Dec 27, 2007
i cvant put ringtones on my sidekick slide and i want to know how to put some on with a usb cable?
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
