My onn television will not do anything a bleep sound is
My onn 20''lcd tv will not do anything a bleep sound is coming from the speakers whats wrong
  • 4 Answers
The bleep sound is it constant or is it in bursts? This is a fault indication of probably, Video card stabilization or power supply issues. Have you checked the unit to see if it has burnt out FET's or bad Capacitors?
Posted on Aug 01, 2009
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
Am facing pblm wth my 26 inch lcd.. cant get sound output from the tv whenever i switched it onn, after several on nn offs of the power am getting sound output.. wat may the pblmm
The problem in that case is loose connection.Plss check first the wiring of the speaker then the speaker then the amplifier located at the board of your television.Try to fix wiring use soldering iron if there's a loose connection at the board..
Aug 21, 2011 | LG 26LX1D 26 in. LCD HDTV
Samsung flat screen wont come on, hissing noise then bleep repeated every 10 -15 seconds or so, sounds a bit like a cd whirring and trying to reset followed by bleep. tried turning on/off at...
Please let me know what kind of tv it is(Plasma, Projection(DLP, CRT or LCD rear projection) or LCD tv) so that I can tell you whats the source of the problem. It sounds like its a DLP tv but I would like to be sure
May 30, 2011 | Televison & Video
My Toshiba 62HM95 DLP TV does not work with my PS3 via HDMI or Component cables. Is the TV not compatible or is something wrong?
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Nov 22, 2010 | Toshiba 62HM95 62" HDTV
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
Nov 27, 2009 | Televison & Video
No sound coming out of my TV
turn it up! otherwise go into the menus and turn your speakers on. if not then have a tech look it over. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I HAVE A NEW SAMSUNG LCD TV,SOMETIMES I GET BRIGHT GREEN SPOTS ON THE SCREEN,WHAT COULD BE WRONG same here
do you have a sound system or speakers close to or on the tv? if so that is your problem. the magnets on the speakers are interfering with the metallic board in the lcd screen.
Jun 01, 2009 | RCA R52WH73 Projection Television
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
Electro Med Services...
