Question about Magic Chef Washing Machines
As soon as my washer gets to the spin cycle, it just hums. Any solution?
  • Magic Chef Master
  • 1,527 Answers
Could be the module board this controls the spin cycle
shaun
Posted on Jul 29, 2009
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Hot point washer hums
it shouldn't do any damage unless the spinning washer is broken. mine hums and rocks from side to side. should not be a problem.just check that nothing is blocking the spinning washer. because that could be a cause for the problem. if it isn't blocking and the humming gets worse i is probably a fault in the actual unit. u should probably call an expert.
Mar 08, 2012 | Washing Machines
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
50 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
