Question about Epson Stylus Photo R220 InkJet Printer
Epson R220 paper feed lop sided and jammed
Others seem to have the same problem - any solution?
  • Sandy
    Sandy Feb 21, 2012
    My printer is the HP Officejet J5780 All-in-One....& they're no paper jams. The problem is that the hinge is messed up on the back left corner of the printer COVER. Is there a way I can fix it or will I have to take it to a repairman?
  • 3 Answers
Try putting a thick piece of card thro the paper path. this tip was given to me by an approved epson repairer. evidently paper pieces and other bits get stuck in the paper path. hope this helps , good luck
Posted on Nov 30, 2007
This works check it out ebay item no 220438393884
Posted on Jun 19, 2009
My Epson R220 keeps pulling the paper in on the right side only, causing a jam. Any suggestions?
Once you place the papers in the tray, adjust the paper holding tray knobs present on either side if the tray such that it holds the paper kept in the tray firmly on both the sides. This will ensure that the paper is fed into the printer in a straight maner even though your printer pulls the paper only in the right side.
I hope this helps in solving your problem.
Thanks
Mar 14, 2010 | Epson Stylus Photo R220 InkJet Printer
My epson R220 is feeding the paper in on the right side only.
The roller pin on the left side is possibly jammed. Try to check it, and free it anyway you can. Could be paper jamming it, also.
Mar 14, 2010 | Epson Office Equipment & Supplies
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
The printer is jammed
What is jammed carriage,paper feed or cartridges.
Dec 08, 2009 | Epson Stylus Photo R220 InkJet Printer
My Epson r220 photo printer is giving false paper jams. What can I do?
the false paper jam problem is creating by paper out cansor so please this is the repairing mater you care it a repairing shop.
Jun 23, 2009 | Epson Stylus R220 Photo Printer
Printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
May 01, 2009 | Epson Office Equipment & Supplies
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper Will Not Load
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
233 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
