Need help with an emx300 mixer/ amp, burnt
I need help with an emx300 mixer/ amp, it is operating but need to replace a burnt resistor that is unidentifiable, it is on the LC90490 BOARD i think it is for power regulation/distribution, about 2 watts, colors are:
brown-black- ??- gold
Ta
  • Audio Player... Master
  • 5,151 Answers
Well I can tell it's 1, 0, something at 5%. However that 3rd band is the multiplier so It could be anything 1 ohm to 1 megaohm. The only way to find out is with a circuit diagram. Try having another look around the board, sometimes the same type of resistor is used in another place.
If you can't find one and can't get hold of the diagram try a 1k or a 10k or a 100k resistor etc. One might work!
Posted on Sep 27, 2009
Ic burned
which ic burnt? if in the output (amplifier) stage it is probably a transistor (or pair) that went out. you will also need to replace the biasing resistor and diode. if in the input/preamp stage any general purpose 8 pin op-amp will work. Be careful when soldering this unit, it has a multi level circuit board. If this unit is out of warranty (over 2 years old) It will probably be more economical to purchase another unit imo. good luck.
Mar 22, 2014 | Behringer Pmp6000 Powered Mixer 1600w 1600...
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Resistors burnt out & I cant make out the colour code as they are burnt black. how do I know what resistance they are so I can replace them?
Hello, resistors burnt out, why? If you replace the resistors will the new ones burn out? What you need is a diagram of the unit and you can get the resistance readings from that. But the question still remains, what caused the burn in the first place and have you repaired that?
Feb 20, 2011 | PowerBright Power Bright 3500 Watt Power...
I need help on changing a fuse in PMP3000. The mixer went out on us one day, so I hooked it into an amp that we had. It works good as an unpowered mixer, but cannot get it to work as a powered mixer. I...
No, that is NOT what the problem is.
The fuse protects the power supply. The power amps have failed. The usual cause is an arc between layers of the multi-layer circuit board. The labor to repair the power amp module is extensive. I have repaired several.
You can find new amp modules and I would purchase a new one and drop into your unit. The amp module is an HCA2400.
There is probably $15 of parts blown in each side of the power amp and it takes about 6 hours to repair. One has to grind out the burned area (internal layers not necessarily visible on surface) and re-insulate and then install jumper wires to replace those taken out.
Each side of the amp will likely take out 3 switching MOSFET transistors and often a Zener diode. Sometimes a low resistance metering resistor will be fried with smoky residue underneath the board. When this happens two small surface mounted resistors will be blown open. Great care has to be taken when insulating the board damage and replacement of the blown circuit traces.
You can find HCA2400 power amp module replacements for about $175 online.
Use of the unit as an unpowered mixer is a bit dangerous as if arc re-establishes it can fry the power supply taking out two very expensive IGBT's and many other components. If the mixer still works, then your whole power supply is still OK.
Sep 09, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
The relay switch clicks but does not power up my yamaha emx300 pa amp/mixer.
I have one like it in my shop
The main power transformer has gone bad
Yamaha has them in stock
Aug 04, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Burnt plug connection from resistor to blower
You need to buy a resistor and plug kit, This is a common concern and you can buy them from your local gm dealer
Jun 11, 2010 | 1999 Oldsmobile Alero
Burnt res and capacitor
which inner panel do you have as theres a few
Apr 02, 2009 | Kenwood KM300 Chef Stand Mixer
A901 has stopped working
Hello.
first press the boton green inside of the machine, when up the head.
if not working .
then is problems the capacitors and resistors.
Regards
Kenwood Chef Restore
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
DBX 100 Boombox
I don't recommend this, but the resistor you speak of is probably a small fuse. Try jumping out the fuse, then turn on unit for brief moment. If it powers up, fine. Replace jumper wire with 1 amp fuse. If not, take to prof. tech.
Apr 12, 2008 | Audio Players & Recorders
50 people viewed this question
 Grubhead
Grubhead
