E15 means that water has gotten into the base pan below the dishwasher and it is now in flood mode. You've probably noticed that the drain pump will run all the time now as well. What that means is that water has worked it's way down into the base pan below the dishwasher tub causing the unit to do nothing but drain. This is normally caused by the drain being clogged or too many suds in the tub causing the tub to overflow a bit. Either way, you'll need to uninstall the dishwasher and tip it forward at a 45 degree angle to drain the water out of the base pan. Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and pour a gallon of water in the dishwasher. If it drains it out right away and doesn't wash or refill, you still have water left in the base pan to try again, otherwise you're good to go.
Now if you don't want to do all this work just to get your dishwasher working again and you have time, let the dishwasher just sit unused for a week and the water in the base pan will evaporate as time goes on and the dishwasher will start working again after a week.
SOURCE: Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
SOURCE: Bosch dishwasher showing e:15 error code.....how do you fix it?
E15 means that unit doesn't think it's getting water
If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced
