Question about Dishwashers
Amana ADW862EAS dishwasher leaking out of the bottom of the door on both sides.
  • 4 Answers
Check the gasket to make sure it isn't broken or lose
Posted on Jul 28, 2009
The Amana dishwasher door locks and will not open after the dishes are washed. I cannot open the door- what can I do?
Try switching the power to the machine off, or un-plug it.
If this doesn't work, lean gently against the machine door (the latch may be too tight and the spring can't pull it open).
Sep 15, 2010 | Amana 24 in. ADW862EAS Dishwasher
My dishwasher wont drain. What do I need to do?
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 30, 2010 | Amana 24 in. ADW862EAS Dishwasher
Why is water leaking from the bottom of the door? Do I need a new seal?
Hi, Yes... Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 20, 2010 | Amana 24 in. ADU5000D Built-in Dishwasher
Leaks on left side bottom of door
Hi
Thanks for using FixYa. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 26, 2010 | Amana 24 in. ADU7000C Built-in Dishwasher
The rotating piece on the bottom of my Amana QT is not rotating
check that the upper and lower spray arm nozzles are not clogged with particles if they are remove them a nd clean them out also see if there is a screen in the bottom of dishwasher under lower rack clean it out if you can also purchase a bottle of dishwasher cleaner from your local supermarket use it in a empty dishwasher first run tap closest to machine to make sure water is hot red directions on bottle it works very well and dishes will come out much cleaner also use a good gel like electra sol dihwasher gel
Jul 21, 2009 | Amana 24 in. ADW862EAS Dishwasher
My ADB1500AW Amana dishwasher is leaking at the water fill sensor
i have adb1500 i have replaced all the board on front of door, and it leaks at the bottom of door.
May 02, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
Dishwashers Logo
108 people viewed this question
Top Dishwashers Experts
