Question about Honeywell Water Heaters
I have a Honeywell ST699. Is about a year and a half old. It now repeatedly resets itself to midnight, then goes on for about 3-4 hours, before resetting itself. What is wrong - do I need to replace it?
    President:
  • 704 Answers
Check to make sure the built in battery pack is working (holds a charge). Without a functioning battery pack, some timers will not work properly and will only operate for a brief time before resetting itself when the battery pack discharges.
Usually any timer that utilizes a backup battery to retain the program settings will require replacing the batteries or battery pack annually.
You can also check the Honeywell site for more details on your specific model number.
http://europe.hbc.honeywell.com/products/pdf/en0r8439uk07r0101.pdf
Posted on Jul 28, 2009
Leaking water, losing pressure and locking out - this boiler is 9 years old and recently kept losing pressure and then locking out.
9 yrs old its like anything else depends on maintenance and quality of unit --not safe since if safety doesnt shut down unit much more damage can occur
Sep 21, 2016 | Water Water Heaters
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Pr sw failed to close
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
RUUD 100-199 GAS WH keeps turning off
check regulator @ gas meter or bottle station is set to correct presure, may need replacing.
Oct 10, 2012 | Rheem RUUD G100-200 Water Heater,gas,100...
Why is the clock losing time on my THR860SUK programmer, loses approx 2-3 mins per month.
This is Honeywell digital thermostat.
Warranty is 1 year for workmanship
call Honeywell Customer Care at 0845 604 2893.
Settings are saved with back-up feature, so external power outage or intermittent short should not affect internal time clock. That says the internal electronics are causing issue.
Instruction manual does not have troubleshoot section:
http://www.homexpertbyhoneywell.com/Documents/EN%20Manuals/THR860SUK-EN-d04.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Honeywell Water Heaters
Blinking red light no heat
It sounds like you are actually in lock out. Recycle is when during a call for heat, the flame goes out, the unit will try to restart itself. Hope this helps
Nov 10, 2009 | Water Heaters
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Water Heaters Logo
415 people viewed this question
Top Honeywell Water Heaters Experts
paulcarew
Lawrence Oravetz
Steve
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
