Question about Gateway M305CRV Notebook
When I turn on my gatway md7818, it boots up but screen is black except for the cursor arrow
    Scholar:
  • 82 Answers
Check your time setting on Bios page.
Try to run F8 to safemode, scan your computer or defragmented
You may have spyware or virus is keeping you away from booting.
Check your memory size, you may need to maximize your memory.
Posted on Aug 16, 2009
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    Fix my laptop
    Do you see the cursor blinking in the black screen?
    Try booting to safe mode. Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode and hit enter. Once you are inside safe mode, install RadarSync and scan your computer with it then update the outdated drivers.
    David
    Jul 06, 2013 | Sony VAIO Computers & Internet
    I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
    Try running the check disk utility.
    To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
    Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
    If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
    In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
    In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
    May 21, 2012 | Toshiba Computers & Internet
    Just have a black screen with mouse arrow after input password
    press f8 , when it turn on go to start and use system restore
    Mar 11, 2012 | Computers & Internet
    Windows is not loading have black screen with white cursor then goes to acer and fast out again to white cursor
    Hello, doing a "last known good configuration" Works most of the time. Here is how to do it:
    1. Make sure your computer is powered down.
    2. Turn your computer on and immediately start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot options.
    3. Use the down arrow on your keyboard to select the Last Known Good Configuration (Advanced) option.
    4. Press Enter on your keyboard and cross your fingers.
    Good Luck!
    Mar 31, 2011 | Acer Computers & Internet
    When i turn on my laptop i goes through the regular start up and everything then after the welcome screen it just turns black and i can't see anythign except the cursor. even turning on the laptop in safe...
    If the system will not boot into safe mode, you will most likely have to reinstall Windows. You can also try the "Last known good configuration" boot option from the F8 boot menu, I find this doesn't work most of the time, but worth a shot. Be sure to back up your data before you reinstall your operating system.
    Mar 24, 2011 | Toshiba Satellite L455DS5976 Notebook
    Laptop cursor jumps around, turns crosshair, screeturns black
    windows vista is probably the problem...have you tried running a virus scan? McCaffe...could actually have one from the factory
    Oct 05, 2009 | Acer NSK8458AN Keyboard
    Computer won't boot Windows Vista. Screen goes black with cursor arrow.
    In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
    Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
    in both the cases system will work .
    Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
    Gateway M305CRV Notebook Logo
    249 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
