I HAVE AMANA A/C.MODEL PTC135A25AC WE HAVE PROBLEMS WHEN INSTALL NEW BOARDS THE NEW BOARDS HAVE ONE BUTTOM ON THE CENTER AND HEAT,COOL,OFF ON THE OTHER SIDE THE PROBLEM WITH THIS BOARDS WHEN PUSH FOR COOL THE COMPRESSOR WORK ONLY FIVE MINUTES AND CUT OFF AND NOT WORK MORE. IF WE NEED MORE COOL WE NEED PUSH HEAT,OFF AND COOL FOR COMPPRESSOR START TO WORK I HAVE THIS PROBLEMS ON ALL NEW CIRCUIT BOARDS ON ALL PROPERY WE HAVE 3 HOTELS WHIT THIS PROBLEMS
  • 614 Answers
When you change the board on an Amana youmusty program the board. You should have gotten a sheet that shows you how to do this. I sell Amana PTAC units and all boards have to be programed for heat pump or electric heat.Russ
Posted on Jul 28, 2009
  • James Stopp
    James Stopp Jul 28, 2009
My 7yr old Amana PTAC unit, Model PTH123B50AJ sometimes works and sometimes not. I had a repair tech check it & he told me the control board was bad and they wanted $440 to fix it. I told him no,
EBay often has the control boards for Amana heat pumps, and installing them is fairly straightforward, provided you have some experience with electronics, a soldering iron, etc. Amanapartsonline.com may also be able to sell you the part, which should run between $50 and $150.
Given, however, that the thermostat is also showing problems, as well as what parts are going for these days, I'd seriously consider upgrading to a new unit and selling the old one on Craigslist to offset the cost a bit. If you can find an HVAC technician, someone who's learning HVAC, someone who just wants it for a guestroom where it need not work perfectly or a landlord who can afford to have a secondhand unit fixed and put it in one of their properties for their tenants to buy your fixable old one for a few hundred dollars and a new one only runs about $700, your upgrade will cost less than having the 7-year-old unit repaired, plus you'll be recycling.
Aug 31, 2012 | Amana PTH123B50AJ Heat Pump,12000BTU,...
I have a new ptac that won't cool, why?
The condeser fan blade is broken. I work at a place where 75% of these units have cond. fan broken in same place.
Mar 22, 2012 | Amana PTH123B25AJ Heat Pump Air...
My Amana heat pump model PTH153B50AJ does not cool properly. The compressor comes on and the fan works.
This sounds like a freon problem your system probably has a leak in the system somewhere. Amana has tons of problems with there equipment. They make there coils paper thin and they split especially on a heatpump. Amana used to be a good brand and then got bought out by goodman manufacturing and have turned there product into ****. How old is this unit?
Jun 14, 2011 | Amana PTH153B50AJ Heat Pump Air...
Window AC Model No. : LG LWA18G 2DF1AK42 IS THERE INBUILT HEATING FUNCTION? HOW TO USE?
Please try to understand with your model, the tonnage and also whether it's cool only or heat & cool. 12,000 (12)...........means 1 TR. with this help your a/c is 1.5 Tr and if it's heat and cool definately there wil be indication in the model cde it self. Ex.......A18TH DF..... like this. There will be H added in the model code itself. Yours is not heat mode. Is it helpful?
Dec 13, 2010 | Amana PTC094B35AM Air Conditioner
Heat is not working. Just blowing cold air no matter the setting
is the "cold air" just room temperature air. put it on cooling and see if its colder than the air that is coming out of it when its on heating leave it on for a few mins make sure its cooling to.. it could be the reversing valve not pulling it onto heating if it can cool and not heat.
if its not cooling or heating it could be a few different problems. gas leak ,pcb boards ect.
Nov 09, 2010 | Amana PTH123B35AE Air Conditioner
Display went out on thermostst, breakers are still on "on", is there an internal reset button?
Most PTAC's have a reset on the power cord where the plug is. If this doesn't help I can find out. The new boards are a little tricky. Is this model touch pad or knobs?
Jan 04, 2010 | Amana PTH123B25AJ Heat Pump Air...
I HAVE A AMANA PTH153B50AE PTACT UNIT. ANOTHER
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Apr 06, 2009 | Amana PTC153B50AJ Electric Heat Air...
Need to know what the settings are for the range adjustment A,B,C,D slide switch on the front panel on a Amana PTH123A35AC PTAC
Here they are;
Position A, Cool 70-78, Heat 65-73
Position B, Cool 68-81, Heat 68-76
Position C, Cool 66-83, Heat 61-78
Position D, Cool 63-88, Heat 58-83
Amana calls this a Temerature Limiter and says to only set one switch on at a time. If all switches are off then the unit is at full operating range.
Please rate this answer to let me know if it was the fix.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
