Question about Amana ATB1832AR Top Freezer Refrigerator
My Amana side-by-side has the same problem - won't cool or freeze
It's our secondary unit we use in the garage, but 90% of the time the motor runs but won't cool or freeze anything. The other 10% of the time it decides to try to run properly - but it never gets as cold as it should. It's over five years old, so the warranty is useless. Is it even worth fixing? The cost of getting a repairman out here is pretty significant.
    Problem Solver:
  • 13 Answers
The capillay may have got choked partially.... get a service person to look into it
Posted on Aug 10, 2009
Amana ASD2620HRB Side-by-Side freezer running, but not freezing. What could cause this?
What is running? The important motor is the compressor - the one that works with the refrigerant to supply cooling. If it is not running you can check the start relay/capacitor. If they are good, make sure that electricity is reaching the motor windings. If the thermostat stays open, the compressor will not be activated.
If compressor is running and if there is ice buildup on the evaporator behind the back panel, then the self defrost mechanism is not working - could be you have an open heater coil. If you completely defrost the refrig for a day and then plug back in, if it works fine, then it is definitely ice buildup which serves as an insulator and prevents cold air from reaching the refrigerator portion.
Aug 03, 2017 | Amana Refrigerators
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana 'side by side not freezing slightly cool
sounds like you have a restriction in your filter drier. or you could be low on freon. both sealed system issues. you need an appliance tech to check your cooling system
Apr 12, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Amana ATB1832AR Top Freezer Refrigerator Logo
67 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
