SOURCE: Notification Error
make a backup of all files and contacts, because if you have removed the software and still get ewallet popping up you will have to do a factory reset. To do this go to start>settings>system>clear storage and then type in the password normally default 1234 and press yes if you want to lose all data and revert to factory settings.
SOURCE: I want to delete all duplicate contacts on my phone.
It sounds like you have them saved to your SIM card and your phone so just delete the copies off of either one that you pefer.
SOURCE: message received is
Do you have an auto setting button on your monitor? If so push it. Also go to Control Panel>Display>Settings, and change the resolution to 1280x1024.
hope this helps!
SOURCE: There is a notification in
My LG phone also does I just delete my whole inbox and sent messages it worked for me, hopefully it'll work for you too. :)
SOURCE: I couldn't delete song files from T.sonic 850.
I had this exact problem as well. The solution was to allow Windows to "Scan and Repair" the file system. The scan will likely detect all the duplicate 0-byte files created as you tried to delete files, and will remove these. In addition it should resolve the underlying problem such that you can now delete files normally without creating more of these 0-byte duplicates.
