Question about NetGear WG111 802.11g/b Wireless Adapter
Netgear Wireless adapter not working
My netgear wireless adapter isn't working on my xp system. I have a netgear router with two adapters, but they won't work I have to use the ethernet cord to connect to the internet on one laptop which is an older model but my newer model laptop and ipod touch connects with no problem, both wireless. I dont understand what the problem is.
  • Anonymous Mar 23, 2014
    How to Get my netgear wireless wna-300 adapter drive working
  • 1,272 Answers
Hi, Follow the steps below to configure the wireless adapter settings on the XP system:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 29, 2009
  • Jonathan Tomaselli Oct 27, 2012
    Wow, thanks! I had the same problem and your solution worked like a charm!
    Well, it worked until I restarted my computer, and had to do it again, but this time it didn't work. Hmmmm.....
SOURCE:
I am trying to set up my Avertec N1200 laptop with Windows XP to my Netgear wireless router. The router does not have a USB connection, but I have a Netgear wireless USB adapter. Also, I am getting the msg...
The Netgear Wireless USB adapter should be connected to your Avertec N1200 laptop to act as a wireless antenna. The driver for your Netgear Wireless Adapter should also be installed on your laptop. Once installed, click on the Windows Orb button on the lower left corner of your screen and go to All Programs. Look for the installed program for your Netgear Wireless Adapter to open up the wireless utility of your wireless adapter. That's where you should connect the wireless connection and not on Windows Wireless Manager.
Aug 27, 2011 | Computers & Internet
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Cant connect wirelessly
Yes u have to buy a netgear N dongle ...
Because N works on 5 ghz and G works on 2.4 Ghz
You can buy netgear WN111v3
Nov 19, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
In this case can you please tell me what is your wireless router and how may computer do you have so we can check if this is a problem with the wireless router or with the netgear wireless adapter. because if you only have 1 wireless computer so the problem here is with the wireless router we may need to change some wireless settings like the wireless channel .....
Nov 15, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Netgear WPN111 wireless adapter won't connect
Is the computer Windows 98 SE [Second Edition] ?
What is the exact error message that you get ?
Mar 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NetGear WG111 802.11g/b Wireless Adapter Logo
4,392 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
