Question about Canon imageCLASS D761 Copier
My copies have a gray streak running through them? how do i fix that?
  • 37 Answers
If you make copies by laying them on the glass and there is no streak, but the is one when using the feeder.Then you need to clean the glass towards the right hand side, any speck will become a line if the feeder is used. If the line is on prints and faxes as well you most likely need a drum.
Posted on Jul 30, 2009
Streaks on copies
Run the printers maintenance software and run the align print head option and the run the clean print head option and check again and see if the streaking is still occurring.
Apr 10, 2014 | Canon imageRUNNER 2200
Really bad copies
Check your toner levels. If OK Restore default settings on Printer
Jul 30, 2010 | HP Color LaserJet 2600n Printer
Copies come out with gray streaks all the way through the entire page
if you are copying through the feeder check the small glass under the lid has not got any typex or ink stuck to it you check by placing a copy on the glass under the lid and do a copy here.. if no streaks apear then check the glass area.. also if you are printing to it and no streaks appear this area is the cause.. if it happens on teh print side too then you have a drum /dev wear issue and it may need replacing.
Jul 12, 2010 | Toshiba 2060 Copier
The copier's making gray streaks on the paper
For all copiers that use dry toner/ink and a rotating exposure drum, vertical streaks are usually the result of a worn drum cleaner blade. Replace the cleaner blade to fix this problem.
Feb 20, 2010 | Sharp Office Equipment & Supplies
Half looks great but the other half is gray scaled has been getting worse for about a month
1)So, your copie is half with good black color, and other half light, with possiblle white streaks?
IF YES: you need to clean the laser unit and replace the toner cylinder cleaning blade, also check the drum unit - if it got over 25000 copies change it too.
2)So, your copies are half good and half like no toner is fixated on paper?
If thats the case replace fixing roller and bushings, and check the press. roller bushings.
Feb 01, 2010 | Canon USA - COPIERS - ImageRUNNER 2010F...
GRAY STRIPES ON COPIES
clean the glass. it must have streaks
May 28, 2009 | Canon imageRUNNER 210S Copier
I have a Xerox XC 1044 copy machine. Copies have grey streak
You may need to have the devoloper changed. Other possible issues; the corona wire is not discharging the photo receptor belt properly, toner spill in the machine from previous change out. Try using an eraser on the gray area if it comes off easily you may have multiple issues that will require a technician to visit machine.
May 11, 2009 | Office Equipment & Supplies
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Poor quality copies from the Canon NP 7130F
hi im jules_09.have check the drum unit and the fuser unit check the two unit.first of all the drum unit the drum may be scratch or damage that goes with the fuser unit too.
Dec 12, 2007 | Canon NP 7130 Black and White Copier
Streaks
It sounds like the lamp/light is going out.  Open the top and try to make a copy and see if the light stays on the entire time.
Erice
Oct 29, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Canon imageCLASS D761 Copier Logo
108 people viewed this question
old marine
old marine
