Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Gas oven my oven turns for 3 minutes at350 then turns off
  • 262 Answers
Re: gas oven
Sounds like the gas vale it bad replace the gas valve and igniter at the same time
Posted on Dec 05, 2007
0 characters
3 Points
Gas oven keeps going out when lit after 4/5 minutes on my 2011 jayco sterling caravan .. have refilled gas bottels
Check that there is no obstruction in the gas line. Spiders and bugs love to crawl into tight places and build nests or die.
Apr 21, 2016 | Kitchen Ranges
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
Gas does not always ignite
The igniter is not properly.Every time you go to light the stove you should hear a clicking sound.If you only hear it sometimes suspect the igniter..
Mar 31, 2009 | GE Kitchen Ranges
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Oct 02, 2008 | Kitchen Ranges
Will This blow up?
Dont start the oven, the burner valve is faulty, the appliance is not safe call in a repairman.
Aug 01, 2008 | Tappan TGFS_63 Gas Kitchen Range
Error code F-4 & F-3
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jun 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
Oven will not turn off
it sounds like the pilot could be restricted and not heating the thermocouple completley,or the t-couple is there ant drafts hitting the oven?
Aug 02, 2007 | GE JGBP28SEHSS Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
93 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
