Question about Sony PlayStation Portable (PSP) Console
PSP won't come on
My psp wil not come on. It's about a year old. When I plug the charger into it, no led lights come on. The charger and the battery pack are warm to the touch but yhe psp will not come on. Do I need another battery pack? or Charger? can you help me?
  • jcramer2234 Nov 23, 2007
    I'm having the same problem as pathfinder5x my psp works ok but it doesnt charge. it used to only work on my PC charger not the wall charger but now it doesn't charge at all and my battery is dead please help
  • 709 Answers
Hi pathfinder5x,
Sometimes the little yellow connector gets corraded and does not pass the power from the battery to the PSP. Find something to clean up the contacts on the battery, and where the battery connects inside the PSP.
Posted on Nov 23, 2007
My psp go making problem nowmy psp go no display only green light showing
Try my advice by following these steps:
First of all remove your battery of your psp model which is found at cover of backside of casing. Then plug-in charger into it and turn that charger on.Be sure that your Battery isn't inside. then open charger PSP will open. now you can do anything in it but do not remove charger but if you have hacked it with some software then go to its options and click on make normal battery to play psp with the help of battery.
Nov 19, 2012 | Video Game Consoles & Games
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
I have my psp plugged in to the power cord for over a day, still not charged and it wont turn on at all. why ?? please help!!!
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Jul 13, 2010 | Sony PlayStation Portable (PSP) Console
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
My psp dosn`t turne on any more.any help?
do you install custom firmware? coz if you do maybe it got brick. try using pandora battery if it works. if it still dosen't works you may have a hardware problem.
Jul 19, 2009 | Sony Video Game Consoles & Games
My psp battery loses power "quickly" and charges very slow....
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Psp battery problem
the problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Switching on my psp after charging it
Please mention after switching on the PSP power LED turns on or not? ================================================= Suppose without connecting the charger when you power on your PSP you will see green light and you will get sound clear with no display at all and after 1 min: PSP will turn off automatically. then 99% it means that your PSP is bricked.
Aug 01, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
76 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
