fridge cooling freeze up i unplug the unit to defrost plug it back in and works great for about 2...
(More)
fridge cooling freeze up i unplug the unit to defrost plug it back in and works great for about 2 weeks and then begins to freeze up again.it is a Side by Side unit
I changed the water filter ran several pitchers of water as directed. The filter ok light does not...
(More)
I changed the water filter ran several pitchers of water as directed. The filter ok light does not light. Is this a problem? I pressed the water & lock buttons as directed but the ok light still doesn't light. The larger green light above the filter indicators is light.
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new...
(More)
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new 9 years ago. After checking my owners manual I decided it needed a good cleaning, so i took all food out, pull it out from wall, cleaned the condenser coils (lots of dirt) cleaned the condenser fan (lots of dirt)unplugged and open both doors for 24 hours,, started it back up and it worked great for 12 hours-got cold- made ice- cold water from dispenser... then it stopped (no cold air) no water coming out of dispenser,, turned off for 4 hours and then started it back up,,, worked great for about 12 hours and then stopped again, HELP any ideas?
I took it out to fix it because the bar that turns the ice came off. The front assembly with the...
(More)
I took it out to fix it because the bar that turns the ice came off. The front assembly with the blades came apart and I dont know how it goes back together.
