Question about Nikon D50 Digital Camera
Automatic Focus doesn't always work - Nikon D50 Digital Camera
  • 51 Answers
AF only work if aimed at something contrasty. If you point your canera at a white wall you will hear your AF work madly without results.
Posted on Jul 28, 2009
Automatic ford focus 51 plate drinking fuel
you need to have the check engine light repaired first most likely related to heat and or gas issue and a check engine light is not a 1 issue thing code will need to be pulled if you have a autozone they can pull it for free and theres where we need to start .could be anything from o2 sensor to a thermostat ect...
Feb 18, 2013 | 2001 Ford Focus
2006 ford focus automatic transmission doesn't engage its stuck in reverse and is not able to start
look on side of shifter see if there is an emergency release button on it some where
Sep 25, 2012 | 2006 Ford Focus
Exactly what is the function of AF lamp for the E-1600TP
The camera's autofocus system needs light in able to acquire focus. If there isn't enough light, this lamp lights up to throw some light onto the subject. It doesn't always work, for example if the subject is too far away. But if you're taking pictures at an indoor party, say, then the additional light allows the camera to focus on the subject.
Jul 30, 2011 | Cameras
Cant find transmission dip stick , 5 speed manual.
The 5 speed manual transmission in your Focus doesn't have a Dipstick, the fluid level is checked by going under the car and removing a fill plug on the side of the transmission case, you then stick your pinkie in the hole and if you can just touch the transmission lube the level is correct. No Ford except automatic transmission models has dipsticks, and even those have been eliminated on the latest models.
Jun 13, 2011 | 2001 Ford Focus
This lens makes a whirring noise when attached to the camera body. It will not focus in either manual or automatic. The camera works well with the other lens.
Sounds like the focus mechanism is broken on that lens. There's a small screw on the back of it where it meets the camera body, the motor in the camera body turns that screw to autofocus. To me it sounds like the screw is turning, but the lens isn't focusing. You said it also doesn't focus in manual mode, so there is probably something inside the lens that needs repair or replacement. Your best option is to take it to a camera repair shop and ask them for an estimate, camera lenses are not the kind of thing you can take apart and fix on your own. Hope that helps.
May 03, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
I have a 06 ford focus with automatic transmission when it gets cold reverse don't work until you drive it about 2 miles or so drive always works good when it is above 40 reverse works good also
okay your transmission is either bad or something is wrong with the gearing. Sometimes the teeth that make the gears turn chip and it slips and wont let you in reverse. But when they warm up the metal expands and allows your vehicle to go into reverse. Hope this helps ;)
Jan 01, 2011 | 2006 Ford Focus
I cant seem to get a good shot in the dim light. Somehow the program/software could not sense and adjust the lighting and focus (in auto mode).
Automatic mode doesn't always work the best. I would recommend manually adjusting the settings for low light conditions.
Jun 08, 2008 | Nikon Cameras
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 | Cameras
Can not foucus the colors
What model set do you have ? Its probaly convergence ICs faulty.
Jan 07, 2008 | Televison & Video
Nikon D50 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
