Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
Hard to start then won't stay running
This unit is 5 years old and has always performed well. suddenly it has become hard to start and stalls if you try to accelerate. it seems like it's not getting fuel...but there seems to be plenty of fuel flow to the carb.
    Problem Solver:
  • 3 Answers
All of these "starting/running" issues are similar and related directly to one cause. It was suggested several times that the muffler may be plugged, but mine was found clean during a complete teardown. Cab cannot be blamed either, since the fuel filter wouldn't be able to pass anything large enough to foul an orfice.
Very common issue with hot running two cycle engines...ring fouling and loss of compression. The brand or type of oil must be scrutinized, and the mixture kept exact. I would never use anything but Echo or manufacturers recommended oil in these units ever again.
Posted on Nov 24, 2009
What shall I do my car running normally but suddenly the engine stop running and never start again.
need more info, year,make,model, is the engine light on have you retrieved all engine codes, when turning engine over, is it spinning very freely or just like it always did,
RE POST with all this info. to get a better diagnoses
Problem 5 Engine Cranks But won Start
http://www.linnbenton.edu/auto/perform/no_start.html
Engine cranks but won start
Feb 05, 2016 | Cars & Trucks
STARTS BUT WON'T STAY RUNNING
Could be something as simple as a dirty fuel filter.
Get a can of quick start at the store and have someone start it up, when it wants to die squirt a shot into the intake ... if it runs again for a bit you have a fuel delivery issue. Check the fuel pressure to see if the pump is functioning properly.
Mar 18, 2015 | 1997 Jeep Grand
Starts but stalls right away
Have you checked your fuel pressure? Could be the fuel pressure regulator. Hard to say without a year and model of the jeep.
Nov 24, 2012 | Cars & Trucks
Mower starts good but only runs 5 minutes befor stalling out and won't start again until cool. It idles OK when blade is NOT engaged. Cause? And how do you set the carb adjustment screws to max. p
No adjustment for carb on newer mowers. All mowers now have a low oil cutoff. Ensure oil is full. 30w oil. If any grey is observed vin oil drain all oil. Moisture in oil. Dump old oil out every 2 yrs and refill. Ensure spark pluf is clean and gapped correctly. Ensure air filter is clean. Replace spark plug and air filter each year. Always use Stabile in gas. Spray outside of carb with carb cleaner to ensure proper choke movement.
Sep 24, 2012 | Toro Garden
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Honda accord 1994 will start but won't stay running
Does it stall as soon as you let go of the key
Jan 15, 2012 | 1999 Honda Accord
Just shut off the care returned 2 hours later no go got a boost went for a drive left the car running for awhile than it start to get like it was going to stall went on g=for a littlwe while than died....
Hi your problem sounds like the battery is gone and won`t take a charge. When your engine is running the alternator is supplying the electrical power to run the car ( and normally charging the
battery as well )
Even though it seems strange for the battery to go suddenly, it does happen.
How old is the bat. Most last about 5 years with normal driving ( batterys last longer if the car is used every day )
Anyway i hope i have been of some help to you.
John (south Wales UK )
Jul 05, 2011 | 1995 Honda Civic
1991 geo storm stalling at idle
maybe try replaceing the ingnition modual. that part can do a lot of weird things to these cars. its located inside the distributor cap, really easy to do. about $40 and 10 mins or less. sometimes as they start to fail they do odd things sometimes but not always
Mar 13, 2009 | 1991 Geo Storm
Won't stay running
sounds like you have a bad ECU unit. have it checked.
Dec 28, 2008 | 2002 Jeep Grand Cherokee
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
408 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
