Question about Dryers
Whirlpool dryer, elctric runs but squeels. sometimes it stops squeeling once it's run for a while but lately it seems to do it the whole time. it does get quieter after it's run for a while
    President:
  • 1,922 Answers
Sounds like your "Drum Glides" need replacing, open the door and cheat the door interlock and you should be able to hear it closer by bottom of drum by lint filter if yours is located there depending on model
Posted on Jul 29, 2009
2002 highlander--started squeeling from the belt area in Feb. Had belt replaced, was worn. It would squeel on starting then stop. Now turning on a/c makes it squeel. Fan works and after a little while
try cleaning the cogs that the belt runs around some times the belt puts a layer of rubber on them when the belt slips which makes the new belt slip if not could be a bearing in the pullys the belt runs around
Aug 14, 2012 | 2002 Toyota Highlander
Whirlpool lgr8648lwo squeels when running no other problems.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 10, 2011 | Whirlpool LGR8648 Gas Dryer
11087088601 dyer squeels at start; will stop after a bit
The belt is loose and is most likely due to the belt being stretched out. Replace the belt and the tensioner also to solve this squeal.
Apr 14, 2010 | Dryers
I have a Whirlpool Duet dryer WED9200SQ0 that has been
Sounds like it. Or your seal around the door is about to give you a headache.
Nov 06, 2009 | Dryers
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Dryers Logo
67 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
