Computers & Internet Logo
l
lennox beharry Posted on Sep 22, 2017
Log in to my pol account - Computers & Internet
How to use pol ?
The Pol function converts coordinates from rectangular to polar. Pol(x,y) converts the rectangular coordinates (x,y) to polar coordinates (r, theta).
For examples and instructions, see page E-37 of the manual and example #036 in the Appendix.
2helpful
Problem with casio 991 es
In the COMP mode (press MODE 1 to get there), press
SHIFT [Pol] (-) . 1 7 SHIFT [,] (-) . 4 7 =
[Pol] is on the "+" key, [,] is on the ")" key.
1helpful
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Gmail does not load
Try the below steps on the PC and you may be able to open gmail.
1. Go to C:\Windows\System32\GroupPolicy\User (usually GroupPolicy is hidden so make sure show hidden folders is enabled)
2. Once in this folder there should be a file called: Registry.pol
3. Delete this file and VOILA! Everything is reset to defaults and it should take effect immediately. If not then just log off and log back on, you don't have to restart.
5helpful
Call Customer Service Support 1-8O5-465-751O For Help how to log out from account
If her account is still open (not logged out) then you can logged out from ither page, and then log in your account. To log out, you need to open the FB page and go to "account" on the top right, then select "logout" from the dropdown menu.
13helpful
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
11helpful
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
How do i find my forgotten ID for ffxi
Hi buddy you just need to Call SE's help line on the phone. They will ask you some security questions(safety) to verify that you really are the owner of that account (kind of annoying, but they have to do it to prevent your account from being stolen). They should give you your PoL ID and password, and then you should be able to log in just fine.
I hope this will work plz vote
5helpful
2answers
Grand Canyon Tech
Grand Canyon Tech
