SOURCE: Jacuzzi Leaking
you need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
SOURCE: Jacuzzi - GFCI keep tripping prventing Jacuzzi
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
