Question about ASUS DRW 2014S1T - Disk drive - DVDRW / DVD-RAM - 20x/20x/14x - Serial ATA - internal - 5.25"... Burner
The drive doesn't read cds but can read dvds!!
The front led stays still for sometime and then goes off.
    President:
  • 1,223 Answers
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and then DVD , it's normal. Pls rate my solution if I helped.
Posted on Nov 19, 2013
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Can read cds but not dvds
Try this, but if the problem persists, you need to replace the drive. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers.
Posted on Mar 23, 2007
guly
  • 67 Answers
SOURCE: dvd troubleshoot
try to clean the lens using coton and water if not working change the lens.
Posted on Sep 16, 2007
aferrell09
  • 105 Answers
SOURCE: Matshita UJ DVD-RAM 860s can't burn CDs or DVDs
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start
Start button, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
The system will automatically rebuild the registry records when you restart your computer. Hope this helps.
Posted on Mar 27, 2010
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
Cd/dvd drive on my Dell latitude D810 will not read
Try to clean the laser within the dvd drive with a soft material. If this doesn`t work, try to hear if the cd or dvd is rotating in the drive. If not, the drive should be repaired b specialists.
Jul 29, 2009 | Computers & Internet
My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
well look for cds that are thicker and sturdier. some low cost CDRs are too thin and/or soft that they cant handle the heat generated by the cd drive.
Jun 04, 2009 | Acer Aspire 4720 Notebook
Dvd writer stopped reading cds even at boot up
try autofixer from microsoft offical page.if doesn"t work
http://www.microsoft.com/downloads/details.aspx?familyid=C680A7B6-E8FA-45C4-A171-1B389CFACDAD&displaylang=en
Apr 26, 2009 | Computers & Internet
Toshiba satellite a65-s1762 dvd-ram drive problems
Take the laptop *and* your DVDs/CDs to a qualified technician.
It seems like the drive is "intermittently" failing, and needs to be replaced.
Apr 22, 2009 | Toshiba Satellite A65-S1065 Notebook
Will not read or burn dvd's
dear friend
this is common probs for notebook dvdrws
they lack quality (all brands)
after sometime drives stops writing dvds, then reading them
after sometime, writing cds and eventually reading cds
in 5-6% cases drives stops to read cds first
sorry friend you have to replace the drive
and if it is in warranty
go for rma
thanks
Apr 11, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
DVD drive plays dvds but does not recognize audio cds.
Common problem. If it's not of the software or dusty optics of the drive, it's because the lasers used to read DVDs and CDs are different. Sometimes fails only one of them. Take it to your local repair center or warranty service or... buy in addition CD-ROM/CD-RW drive
Jan 18, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
DVD drive reads DVDs but not CDs
Sep 28, 2008 | Computers & Internet
DVD drive does not play or recognize DVDs but does play CDs
Find out what model drive you have and see if there is a firmware update for the drive.. Sometimes they loose there brain and need to be reprogrammed. If that dosent fix your problem, then the laser is on its way out.. Use a different laser to read dvds vs CDs.
Sep 02, 2008 | HP Televison & Video
Dvd rom not reading dvd while reading cd properly!!!
The demands on the drive differ greatly for reading CDs & DVDs.
This is a common problem since alignment of the drive is very critical for DVDs and often fails first.
I don't offer much hope, but you might buy a special disk for cleaning optical drives; sometimes they will help.
This article has some tips that might be of use:
http://www.smartcomputing.com/editorial/article.asp?article=articles%2F2003%2Fs1409%2F10s09%2F10s09.asp
Aug 03, 2008 | Toshiba Satellite A135-S4527 Notebook
ASUS DRW 2014S1T - Disk drive - DVDRW  / DVD-RAM - 20x/20x/14x - Serial ATA - internal - 5.25"... Burner Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
