SOURCE: Kenmore elite 790 79363400 dual fuel oven door does not close all the way a
if your locking it to make the light goes off it sounds more like the light switch on the oven needs to be replaced
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
SOURCE: oven anti-tip bracket
Hi Jodie,
The anti-tip kits are installed on the floor behind the oven. They're installed BEFORE the oven is moved into place. They are "U"-shaped and when the oven is slid into place, the "U" locks into the back legs of the oven to lock it down.
You can tell if yours is so equipped by simply sliding the oven out away from the wall about 10 inches then looking behind it on the floor. Slide the oven out by opening the door about 5" and place your hands inside... then lift and pull toward you at the same time.
Here is the anti-tip kit for yours... If you see this down there, then you're good to go. If not, order both of those parts (in the previous link) 'cause you'll need them.
Hope this helps!
SG
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
