Question about Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range
JDS8850BDS Dual Fuel Everything works fine except
JDS8850BDS Duel Fuel - It takes forever for the oven to heat up and also seems like it takes longer for items to bake. It sounds like a fan is running and it's not the convection fan? Everything else works great. I wonder if the cool down fan is running the whole time?
bigg t
  • 640 Answers
SOURCE: Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Posted on Aug 15, 2007
Model #JMW9527CAQ convection oven has no display visible.Started out very dim and eventually went to no display on the front display .
Posted on Jan 12, 2008
ginko
  • 19396 Answers
SOURCE: Replaced Frigidaire model # FEF369CGTB
Use the original 316101004, click to open retailer webite
Posted on Apr 19, 2008
  • 409 Answers
SOURCE: Convectin fan in Jenn Air Stove
sounds like the fan or motor is not working at all. have a technician replace it.
Posted on Sep 13, 2008
protek480
  • 1714 Answers
SOURCE: Kitchenaid electric convection range - preheats
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
Posted on Jul 25, 2009
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Rangemaster Toledo
we had the same problem - a power cut then the clock flashed up 'auto' preventing the oven from working.
After downloading the manual from the rangemaster website we learnt that all you need to do (for the classic dual fuel anyway) is to press in the 2 buttons on the left and set the time using the + or - keys. Dead easy and Christmas dinner is back on!
Sep 02, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem i have a memory that there may be a fan fail stat mounted close to the element. worth a check
Apr 01, 2007 | Rangemaster Professional 110 (Duel Fuel)...
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Jenn-Air JDS8850 Dual Fuel (Electric and Gas) Kitchen Range Logo
75 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
