Question about Canon DR-9080C Path-Through Scanner
I have a canon dr-9080c scanner and it is having intermittent problems scanning the entire page of a document. for example-- 100 page document --page 1-75 scans perfectly--page 76-100 only the center of the document scans, about 1 inch of the margins do not scan.
    President:
  • 2,306 Answers
Sounds like you need a new CIS unit, the scan assembly or its lamps are flickering.
Posted on Jul 28, 2009
  • 490 Answers
If it is not hardware problem as suggested, try uninstalling the device, restart Computer, run Scandisk/Chkdisk and reinstall the driver. Any software glitch will be resolved thru this.
S. Mohan
Posted on Oct 18, 2009
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
S. Mohan, Chennai, India
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Jul 14, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
If I put a large amount of paper in my canon dr-9080cscanner, it only part of the page until ti gets to a specific part. For example I put in 100 pages and it scans the middle inch and a half until it gets...
I could not understand your problem clearly.
If I am right, you are saying that if you scan 100 pages, about 80 pages are scanned properly and the there is problem with the balance 20. Clean the rollers throughly with a damp cloth and also the ****** rollers. Please swithc of the scanner when you are cleaning the ****** rollers as they are in a 'locked' position in power on position.
If your problem is different, please explain it clearly.
S. Mohan, India
Jul 08, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c Ghosting Problem
Though I've never seen this on any scanner, I can imagine it being a reading glass out of place. This could cause a weaker reflected image overlaying the direct one. Look at the top & bottom glass strips in the transport area. They should look level & unbroken.
Apr 07, 2009 | Canon DR-9080C Path-Through Scanner
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
517 people viewed this question
old marine
old marine
