when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
You're describing vague, conflicting information. At first glance, I would think you have something stuck in the pump. But then it would be there in the rinse-only cycle also.
The anti-bacterial mode heats the water up to about 180F. This kills bacteria, and it also speeds up the action of the detergent. It could be dissolving whatever is in there.
The humming noise wasn't there in the rinse mode... The heater isn't on in the rinse mode - everything else is. But I've NEVER heard a heating element hum.
Cleaning the filter:
The filter is in the back in the bottom right. It's cover is held on by two 1/4 in screws. Under that is a large grate, and I sometimes find stuff clogging the screen (underwater, toward the center of the machine.) I'd start by looking there.
