Question about Mpio FY800 MP3 Player
Can't switch on my mpio FY800
Hello, I have an mpio FY800 for about 1,5 years till today no problem. But now I can't switch it on. I tried to recharge the battery, (despite the display showed the last time I could see it, it's still ok) but the computer doesn't recognise it and nothing happens. (I still have the same computer, no problem with that before) I pushed the reset button as well but nothing happened. can you help? Thanks in advance
SOURCE: windows unable to format my player
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Posted on Feb 03, 2007
SOURCE: mpio not showing up on itunes
We just purchased an MPIO and we are having same issue, media player not recognizing that it is plugged in by USB, however MP3 player is.... Retailer had no clue and said the equipment was not broken.... we have another MP3 (RCA) and it works great !!... need fix
Posted on May 27, 2007
  • 20 Answers
SOURCE: External SD memory problem
The FL100 will only take up to a 1GB SD card
Posted on Sep 04, 2007
SOURCE: won't turn on
either you got a faulty surface mount regulator IC or you got a corrupted flash memory. Try pressing play button, then alternately press volume down (-) and Rewind (<<) buttons. When the "FORMAT? Press Menu" appears, press MENU BUTTON. A LOW LEVEL FORMAT will be in progress. When it's done, reload firmware recovery using MPIO Utility. If however you nothing appears on the screen afteryou pushed the play, rewind, and minus buttons,or still it doesn't power up, you've got a faulty regulator IC. It is the five pin chip colored black with the markings "PHK" (use a magnifying lens to confirm) located on the left besides the battery connector (facing up, with the earphone jack on the top). If you had micro soldering skills, then you can remove the chip and replace, if you can find a replacement...
Posted on Oct 08, 2007
SOURCE: My Mpio FG100 is messed up! Help! Please!
lol thats not how .... switch the hold switch on, press and hold func botton press play while holding then turn on the mpio while holding after that a screen saying"preceed to format? press rec hold for N secs til screen pops up saying that its doing a low level format
Posted on Feb 20, 2008
I just upfraded my Mpio FY800 to firmware 1.20, but I just messed it up a little bit on the half way through of the progress, but it still shows 1.20. My problem is when my mpio connects to the pc, it...
You may want to check with tech services from the manufacturer. I know that most electronics if there is an interuption during a firmware update it can ruin the device.
Jun 19, 2011 | Mpio FY800 MP3 Player
My husband has a Kawasaki drill. he has charged the 2 batteries and neither of them works . he has had it for 1 1/2 years and never had trouble till a few days ago.we have been using it but didn't charge...
check voltage on batterys with volt meter if the batterys are weak try recharging. try them in flashlight or other peice of equipment.. try moving forward reverse switch while pressing trigger and maybe clean battery contacts with eraser.
Jan 15, 2011 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Cant turn on my mpio fl 350 because of discharged battery
Hey! I experienced the same problem as you, found my FL350 wich had been laying in a closet for 2 years, completely discharged.
What I did, was to connect the FL350 to the USB port, a message popped up saying like "USB device can not be recognized", ignore it, it will keep popping up, but don't mind that. I then left the FL350 in my PC with the PC turned on, and left it over night. Today I could turn the MP3 player on, resulting in that the PC found the device and it began charging. So I will leave it there, and in two hours I will go out running, listening to it :D Hope this works for you.
Apr 29, 2010 | Mpio FL350 MP3 Player
How to Replace Battery in MPIO FL300
my mpio FL300 can't conected to my computer,because i've been format it.how to solve this problem?thx.(if ful)
Aug 16, 2009 | Mpio FL300 MP3 Player
Laptop went blank suddenly
chck the memory ,,and reboot the machn..thn c,,if nt tht remov the memory n clean it n put it bck and try
Aug 12, 2009 | Dell Inspiron 1525 Notebook
My mpio player does not come on. When I press the power button only the blue light is lit and it does not go any further. please help
hello.
your chances are:
1st it is broke and still can be used as a small portable drive(like a tumbdrive) after you have formatted it..
2nd: it is facing internal software problems.
you will have to format it though, but before doing so, copy all the mp3s you don't wont to miss from it.
get the MPIO Manager 2 from
http://www.mpio.com/product/productview_fd100.html?view=d
-then format the player and reinstall the firmware using the manager( you will have to install it on your pc first)
- put some mp3's onto it, unplug from PC
and hit the play button. good luck!
Aug 04, 2009 | Mpio FD100 (128 MB) MP3 Player
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
Won't turn on
Apr 03, 2007 | Mpio FL300 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Mar 31, 2006 | Mpio FG100 MP3 Player
Mpio FY800 MP3 Player Logo
47 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
