Question about Husqvarna PRRT850X 960920015 CA 17" Rear Tine Tiller
Rototiller pull start won't pull
This tiller has an 8hp Tecumseh engine. (GardenWay rear tine) It hasn't been started in two years. Started pulling on the crank and then gave it a rest. Went to pull again and the crank simply won't turn. I can't get any length pulled on the pull start. It's as if there's a safety on it somewhere that's in the locked position but I can't figure it out.
Throttle is open, choke on full, clutch is disengaged.
Thanks for any and all suggestions!
    Scholar:
  • 173 Answers
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
Posted on Jul 28, 2009
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
May 04, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Can't start my Troy Built Tuffy tiller. I haven't used it for a year, but it started fine last season. I replaced the spark plug, changed the oil and air filter and filled it with fresh gas. When I pull...
First pull your spark plug out reconnect to the plug wire and ground tot he engine body
Pull the starter cord and see if you have a good clean spark that goes to the electrode and not to the side of the spark plug.
If no spark check your off/on switch
Mar 31, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Wheels turn, tines don't
These machines have an arm to activate the tines independantly from the wheels, make sure that the tine arm is in the on position.
If not, seems like you have a transmission problem, you'll have to get dirty to fix this one and open up the transmission casing to see if its just the link between the tine arm and tine crankshaft that broke or if its more serious.
Apr 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Tiller won't start.
I recently had the same issue with a tiller that hadn't been started in over 8 years. Turns out that old gas had left a varnish coating in the carburator keeping the gas from feeding. Rebuilt the carburator with new float, needle valves and bowl, new Welsh plug. Fresh gas and two pulls later it went to churning. Took a short time to adjust the two needle valves for idle and full throttle and we went a-tilling.
Apr 04, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Despite changing the sparkplug and proper choking, etc. no start
The most likely culprit is a clogged carb - a very common problem indeed on Tecumseh motors. Pull the carb off, open it up, spray everything with cheap carb cleaner (especially the bottom "bolt" that hold the float cover making sure it sprays out of at least two sides as that "bolt" is also the jet), make sure everthing lines back up as you pulled it apart and now try to start it up again! Bet it works, I see it all the time on small engines left with small amounts of gas in the system. Good luck, and I hope that gets ya runnin!
Mar 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Husqvarna PRRT850X 960920015 CA 17" Rear Tine Tiller Logo
782 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
