Question about Grilling
The gas on my Regal 11 is not following right. I cleaned all of the port holes on the burners. Do you recommend someone local (30269) that can fix it?
  • 636 Answers
If you have a propane bottle attached to it, it is probably the regulator that is shot .
Posted on Jul 28, 2009
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Sep 30, 2012 | Heating & Cooling
I have a paloma tankless water heater ptg-74pvn-2 that gives me the error code c2 11. looks like everybody has a problem with this. what can i do to fix it, surely enough they should have some easy way of...
Easy solutions for C2 11:
Rheem is one of the big manufacturers but has disproportionate number of questions at fixya since they try to funnel problems through service techs instead of posting do-it-yourself service bulletins. People want do-it-yourself service bulletins, as appear on the Bosch site for their products. Easy-fix in this sense would be to buy Bosch, and read service manuals aforehand to see if you have testing skills and equipment to maintain and repair tankless water heater.
Easy solution for C2 11 Rheem problem is don't install gas tankless water heater, since all costs are energy and tankless are expensive to install, maintain, repair, and replace for the mere savings of 1-8 per month.
Third solution for C2 11 no-ignition is to clean burner and combustion parts, and sand carbon off the igniter, on a yearly basis, as recommended in manual.
Fourth solution is to call a qualified service technician each year as recommended in manual, and have technician fix problem and catch water heater up on recommended service. This person can check other causes for C2 11 such as bad igniter, bad gas solenoid, low gas pressure, air in gas line, improper unit grounding, bad wiring, bad sensors, etc.
This check-up can also make sure vent drain is working properly and that acidic water vapor and other resulting combustion by-product are going into the household drain and eventually out to sea instead of dripping down into the heat exchanger causing rust and premature failure of exchanger.
Next solution will not solve C2 11 error code, but can address other error codes before they happen: Maintain water heater on yearly and monthly basis as recommended in manual. This is good for folks who like projects.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
More resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
1-800-432-8373
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
Gas oven is working fine but none of the burners are igniting
The little gas ports maybe blocked on the burners, try cleaning the ports, also on the burners there are 3 or 4 small pin holes for the gas to travel, a small paper clip will remove any debris trapped inside these holes once they are clean the burners should light
Oct 30, 2009 | Ovens
All of the sudden my front right burner will not light. I clicks like it wants to light and you can smell the gas but it will not light.All the other burners are working fine.
Take a look at the burner when it is clicking and make sure the igniter electrode is creating a spark. If the burner head is removable pull off the burner cap and head. Inspect the burner head for debris and clean. Make sure any small holes on the burner head are not plugged. There is usually a small hole where the electrode is that a gas must exit for proper ignition. If the burner has a center igniter for two burners then inspect the flash tube for that burner and make sure it is centered and there is no obstructions in the flash tube. On that burner there are little holes located in front of the flash tube call step-up ports. Check to make sure those little holes are not plugged.
Sep 10, 2009 | GE Kitchen Ranges
Smell of gas and question on cleaning
I recommend cleaning heavy cast burners with a wire brush. If for some reason, (moisture in gas), the burner holes are corroded and slightly clog, use a perfectly size drill, and clean the holes BY HAND. Do not use the power tool. Just twist the bit by hand.
Commercial equipment is designed to be under a hood. When installed in a residential application, I would very much expect for the unit to "smell". I would recommend taking the time or money to verify supply gas pressure, and install a regulator if needed. Most all supplies are higher than the equipment is spec'd for, so a regulator, that is properly adjusted, would help solve your issues. Also a reg would save you money on fuel through the years.
May 28, 2008 | Garland H283 Gas Kitchen Range
MY DRYER IS NOT DRYING
I am curious as if you can tell if the burners are firing up. On the Neptune models there is a relay switch that has to function to tell the gas to go into the burner ports at the right time. the same relay switch also corresponds with a electric ignitor to ignite.
Second, the burners and its components must be rated for Natural gas or propane, which ever you are using.
Third, burner ports also has to be clear of debris, scaling etc.
Some have thermocouplers that go out. Some have burner blow back sensors that get worn out or dirty. Those need to be cleaned off by a technician.
It is strongly recommended that a service technician perform this service.
Back in the old days we could have used special tools to clean out each port one at a time, but now they require a bit more skill than old timers like me can do.
Make sure however your dryer is plugged into a properly grounded outlet also.
If you find that it is grounded down, and the gas components are correct, and still doesn't work, I strongly urge you to contact your local appliance repair store for technician repair to be performed.
May 19, 2008 | Maytag Neptune MDG6800 Gas Dryer
Grilling Logo
18 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
