Question about PfaFF Hobby 4260
Pfaff hobby 1142. only goes one way, does not complete buttonhole.
  • bigislandmom Jul 30, 2009
    tech problem for sure, thx
  • A Rumbold May 25, 2013
    Mine does exactly the same thing. It is not gummed or dirty in any way. I have never manage to make a button hole with this system and I have been through every question and tutorial I can find online. I never had a problem with any of my old Singer machines. I am not a button hole novice but this Pfaff has me stumped!
  • 55 Answers
It sounds like the buttonhole mechanism is seized up or gummed up with old grease. try following the linkages for buttonhole mechanism or button to see you can locate the stuck linkage.
otherwise it sounds like a tech job.
scott.
Posted on Jul 28, 2009
I am trying to make a buttonhole for a 3/4" button, using a Pfaff Ambition 1.5. Using the buttonhole attachment the buttonhole comes out to be 3/4 " what am I doing wrong?
Hello, Suzanne -
The buttonhole opening needs to be 3/4". That means the actual button hole stitching needs to be 7/8" - 1/8" larger than the button..
Read the information here:
https://itch-to-stitch.com/proper-placements-buttons-buttonholes/
Best wishes.
Feb 23, 2018 | PfaFF Sewing Machines
Old Pfaff Creative 1459...book does not address how to make a buttonhole. Machine sews only down one side, then stops and makes a giant lump and never goes to the second side. Can you help?
The machine's timing may need adjusting. Has it been serviced recently? If the book does not say how to make a buttonhole, perhaps this feature is not available.
Feb 04, 2016 | PfaFF Sewing Machines
Pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
Apr 13, 2012 | PfaFF Sewing Machines
Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
Jul 01, 2008 | PfaFF Hobby 4260
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Button holes
Hi
Are you using a Pfaff 7570 (or other Pfaff machine with Sensor)? If so, definitely use the sliding buttonhole foot and the sensor guide (slides below the needle plate from the back of the machine. This will keep your buttonholes consistent.
The size is regulated by the Stitch/Pattern Length button and Width button. Select the size you think you'll need (in millimeters).
Test sew your buttonhole on the EXACT same combination of fabric/layers & stabilizer that your garment is. Adjust the length/width of buttonhole if needed. I would recommend a bit wider buttonhole due to the thickness/puffiness of the fleece.
Hope this helps,
Kim
Jan 25, 2008 | PfaFF Creative 7570
Sewing Machines Logo
902 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
