Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Ice forms on the bottom of the freezer and water leaks on the floor water to the ice maker was turned off and that did not solve the problem.
    New Friend:
  • 63 Answers
Assuming that this is a self-defrosting freezer (which almost all are today), the defrosting coil or the timer may be bad. The defrosting coil actually warms up the freezer slightly every X hours. This thaws the ice that starts to form in the freezer. The vapor is then evaporated and exists out through a drip tube to the bottom of the freezer/fridge into a pan. The pan usually has the compressor fan blowing over it to evaporate the contents.
Posted on Jul 28, 2009
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Water from the ice maker overflowing into the ice container. Water also running down the inside of the freezer onto the bottom forming a thick block of ice. It melts,and flows to the floor.
Sounds like the water valve For the ice maker fill is leaking. these are solenoid type usually found at the back bottom outside of unit. turn water to this valve off at connection in wall . You can have that valve replaced
Jun 22, 2011 | Refrigerators
Water freezing on floor of freezer and leaking on to floor in front of freezer?
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Feb 18, 2011 | Jenn-Air JSD2789GES Side by Side...
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire, ice on floor of freexer
check to see if the defrost drain is not frozrn over or stopped up
this is the only way that water can get into the freezer
frost could and melt but dont think that i would check the drain at the bottom of the rear freezer panel if you see ice it is stopped up for sure
if all is clear there go to the ice maker, have had some that are overfilling and runnig over the ice maker into the bottom of the freezer
Jun 23, 2008 | Refrigerators
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
183 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
