Question about KitchenAid KUDR01TJ Dishwasher
How do I replace electronic control board (how do I get to it)? (Several button panels hard to use, getting worse.)
    President:
  • KitchenAid Master
  • 1,922 Answers
Go to "Appliance Parts Pro's" they'll have the board and techs to help youD.I.Y.
Posted on Jul 29, 2009
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Need help with blank TV screen after replacement of control panel
The new board may be causing this--either defective or the set needs a reset of some type---get the board from Samsung or where?
Jun 15, 2012 | Samsung LN40A500 LCD TV
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
The electronic touch control has fallen inside the hood this is the second time it has happened is there a plastic mounting bracket on the switch that has broken? left side of switch I can see a mounting...
Yep! This is a classic problem with the Therador PHE series hoods. Very weak design and NO help from the factory! Just the plastic housing is $82.00 bucks online. The panel is REALLY hard to access and the control boards, inside, fail regularly. The board alone costs over $200.00 bucks! These will fail to switch on the fan or change fan speeds or turn lights on and off or fan off. All of this randomly and arbitrarily so people tend to push the switch buttons too hard, causing the bracket to fail and entire panel body falling off inside. We have had ours propped up inside with two chop sticks for several years now and to get the fan to switch on or change speeds we fiddle with the chop sticks while repeatedly pushing the buttons and sooner or later it comes on. The lights rarely will come on, however. This unit is made by Bosch and they have all the same problems with NO fix except to replace ENTIRE control panel at a cost of $350.00 retail. This is truely an example of modern, fancy kitchen appliance over-engineered ripoff junk. Looks great but it makes sure that the fool who buys into the Brand name and cool design gets to pay and pay again for their naivete'.
Oct 16, 2009 | Thermador 30", 36", 42", 48", 60" Wall...
Washing machine flashes F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Flashes F7 then stops working
You have a stuck pad on the control board. Push every button several times to try and clear it. If that does not clear the stuck pad you will have to replace the electronic control.
Jun 24, 2009 | GE JKS05 Electric Single Oven
GHW9150pw3 is dead
most likely the interface panel(all the buttons and do dads)..there is more to interface than just buttons there are several electronic items there too besides i did the same thing and had to go back to change controls
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
Electronic Control Panel
If several options on the control pad do not work, I'm afraid you probably have an electronic control board that has gone bad. They aren't serviceable and have to be replaced. They can be a bit pricey, however. Most, run over a $100 with some running over $300. A lot of it depends on options and model. If you decide to replace the control board, the overlay (plastic piece with all the numbers printed on it) usually does not come with it, either. You can reuse the old overlay by carefully peeling it off the old control board and reapplying it to the new one. The overlay can run as much $30-$40 as well depending on where you get it. I hope you find this helpful.
Jul 11, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
KitchenAid KUDR01TJ Dishwasher Logo
192 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
