Which wire goes where there are two red one black one red thicker than the other
  • kvn_mcgregor Jul 28, 2009
    sorry about that i am replacing the door switch on a servis 1300 washing machine i was not the one who took it off so i dont know which wire goes where all i know is that there are three wires two red and one black and that one of the red wires is thicker than the other so if you can help that would be great
  • yadayada
    yadayada May 11, 2010
    goes to where on what?? read your post it supplies zero info about what you are doing, where u half asleep wjhen u worte this?
  • 99 Answers
Need more info, where on the machine are you working on?
Posted on Jul 30, 2009
I have a 1996 328is where would the wires go on the starter, i have 3 wires that are off. 2 of them are about 8 gauge or thicker, one is black and the other is red both of them have the same ends on them....
the black wire should be the earth and the red is the livefrom the battery the one post thats left put the red wire on that and put the black one on with the starter bolt that holds the starterto the engine
Jan 27, 2011 | 1999 BMW 328 Series
I took the wires of the thermostat and heating coil and cannot remember how they go back on. I need a wiring diagram to put them back on properly
if you look at the connectors the wires that connect to the heater are larger and the wire is thicker,it doesn't matter what wire goes where on them,also the heater wires should be red and the other is red with a white stripe and like i said it doesn't matter what post on the heating element the wire with the stripe or the solid red wire connects to.the same with the thermostat
May 31, 2010 | Dryers
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
The wall switch that I am replacing, with a 3-way dimmer switch, has 2 black wires, 2 red wires and a green wire. The new 3-way dimmer switch has 2 red wires, 1 black wire and 1 green wire. Question: How...
Ok the RED is Phase and the Black is Neutral... Green is Earth. you have an IN, Red wire, and an OUT Red wire, the rest just go color to color. So in the socket, one Red wire goes to one Red wire from the dimmer, the other Red wire in the socket, goes to the other Red from the dimmer, then Black to Black, and Green to Green. Be careful do NOT work on it live.
Feb 26, 2010 | Lutron DVW-600PH-IV Slide Dimmer with...
Which are the 12v wires on my car?i have a 1994 volvo 850 and am lost on where to start wiring my new radio wich wires go the power and wich goes to the speakers?
All the qires on your vehicle are 12volt.
Be careful on that. Seakers don't take voltage.
The red wire is normally the power wire to the radio, it is also bigger than the speaker wires. The Black wire is normally the ground for the radio and is also thicker and must be screwed to something on the dash board that is metal and a good ground Now all that is left are the speaker wires and you just match them to the ones you want.
Nov 14, 2009 | 1994 Volvo 850
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Front USB ports
Try here to dload manual which should tell you which is which
http://www.asrock.com/mb/overview.asp?Model=P4VT8%2B
hope that fixes it for you?
Jan 06, 2008 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Washing machine
the wire that is live goes to terminal "l". check which of the other two is neutral and put it on terminal "n". (it is probably the thinner of the two red wires) the remainong wiree goes to terminal "c". usually there is a little circuit diag on the interlock and this may help you
Mar 23, 2007 | Creda W100FW Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
