With the handset in standby mode, press Menu (on the right below the LCD screen). Use the Up/Down arrows to navigate to Call Block. Press Select (the same as Menu). Navigate with the Up/Down arrows to highlight the line Block List and press Select again. Navigate to the line Review with the Up/Down arrows and press Select. Use the Up/Down arrows to navigate to the blocked number that you wish to delete. Press the Mute/Delete button (the center button below 0). You should hear a confirmation tone and either the next number in the block list or list empty should appear on the LCD screen. (You can't delete the entire list at once.)
The procedure to delete a blocked item in the Call Block list is given on page 21 of the full manual. The manual is available from VTech on the product page:
https://www.vtechphones.com/store/pd/3370/CS6919-Cordless-Phone-with-Caller-ID-Call-Waiting . The direct link to the manual is
https://cdn-media.vtechphones.com/products/CS/CS6919/CS6919-X_WEBCIB_V4_20160224.pdf .
I hope this helps.
