Question about Sport & Outdoor - Others
RATCHETING SOUND WHILE IN REVERSE.
MY RIG IS ACTUALLY A MV-700. THE SOUND IS BEST DESCRIBED AS A RATCHETING AND IS MAINLY WHILE IN REVERSE. SOUNDS LIKE THE LEFT, REAR TIRE AREA. THANKS.
  • 29 Answers
HELLO; You need to adjust the linkage it's grinding the reverse gear. GOOD LUCK..... GREASY
Posted on Oct 02, 2009
Can I put reverse cone megaphones on this bike if so what adjustments need to be made custommead
17" Reverse Cone Megaphone Muffler ' Chrome Shorty ...
www.dimecitycycles.com/chrome-17-inch-shorty-reverse-cone-megapho...
Chrome 17" Shorty Reverse Cone Megaphone Muffler ..... Turned out a bit too loud for me so I used handmade db killers - the sound became .... This is the best bang for the buck slip-on one can buy for this type of bike. ... Only thing to keep in mind is that ifyou are gong to run the mufflers with the packing /core, you will want ...
Ask Kevin: Are Reverse-Cone-Megaphone Exhaust ...
www.cycleworld.com > Blog > Ask Kevin
Jan 3, 2014 - Ask Kevin: Are Reverse-Cone-Megaphone Exhaust Systems Making A Comeback? ... Answer: Rob Muzzy once remarked to me that if power is the only goal, individual, one-per-cylinder megaphones can't be beat. ... Back when Honda and MV Agusta were racing air-cooled four-stroke bikes, Grand Prix ...
Reverse cone megaphone mufflers ' Motocross, Supercross & Off-Road ...
dirtrider.net > ... > Fabrication, Welding, Machining
Jun 5, 2002 - 20 posts - ‎11 authors
From what you say it seems like a properley tuned reverse cone design ... If this is right, it would imply that the pulses could be 'in tune' with the cylinder filling ... The pipe is designed so that the pipe pulls the gas air mixture all the way ... As far as restrictions go, remember the 1000 CC street bikes that had a ...
Jan 19, 2016 | Cars & Trucks
Offside door mirror has continuous ratcheting action, after being knocked.
Sounds like the main motor mount pin is snapped.
Unfortunately they are right, you will need to replace the mirror unit complete.
That said, I wouldnt be paying $700. Ring around wreckers and get a 2nd hand one. You'll likely find one in the right colour for your vehicle..
Mar 22, 2014 | 2007 Toyota Yaris
Popping and squeaking sound
The popping sound could be UV joints. But hard to tell if one cannot hear them. Worse case scenario, transmission going. The squeaking sound is probably your struts. The upper strut bearings are probably worn, and that could mean the struts are worn too. Depends on the mileage on your vehicle. The springs twist when under stress and this is what the upper bearing is for. In good shape, it would not make any sounds.
Mar 05, 2014 | 2004 Saturn ION
I can't get the sound to work.
You'll have to remove the cover to the microwave, MAKING SURE YOU UNPLUG IT 1ST. Check to see if it has a small speaker for the sounds to work. Take it to an electronics store and have them check to see if it works. IF NOT, replace it with a similar speaker (doesn't have to be exact, just the same voltage and ohms). If that isn't the problem, if the original speaker or device for sound works, then you've got a problem in the circuit board probably, and not worthwhile to replace it.
Sep 20, 2012 | Goldstar MV-1526 Microwave Oven
1994 Honda Del Sol makes a sqweaking noise when I reverse and when I brake
Sounds like the squeakers on the brake pads are rubbing. This is designed to make the noise you described to let you know it time to service your brakes. A brake inspection should reveal the problem Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 26, 2012 | 1994 Honda Civic Del Sol
We have an HP Photosmart C6180 All-in-One that is making a horrible ratcheting noise upon startup. It sounds like the print head mechanism, or the belt that the mechanism moves on. I'm considering taking...
Often a peice of debris (like a peice of paper) can get in the printhead track and cause the belt to slip. Once this happens the printer should detect it and realign the printhead. If the belt is overly worn or slipping the printer will try over and over to realign- and what you will hear is that ratcheting sound.
From my experience, your best bet would be (as much as I hate to say this) is to dump the printer for a new one (if it's not still under HP's short warranty - and even then it may not be worth the cost to ship it in for repair.)
Dec 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
My drz 110 makes a ratcheting sound and wont turn over
the main shaft has broken and possibly the first gear and right engine case. Common problem.
Jan 06, 2010 | 2005 kawasaki KLX 110
I HAVE A COMPAQ PRESARIO 700 MV WITH LOW MEMORY. I NEED TO ADD ADDITIONAL MEMORY. 700 MV BY COPAQ PRESARIO IS AN OLD SERIED. HOW CAN I RESOLVE THIS PROBLEM.
You'll have to find out the specs for the maximum ram for your model. You can do that from the manufactures site. Then take out a stick of ram and make sure to match the speed like pc100/pc330 etc. The worst that will happen is you may get a blue screen/ lock up or nothing at all will happen.
Oct 25, 2008 | Compaq Computers & Internet
Cant record
Hello, please check this link: http://www.imaging-resource.com/badccds.html According to this you may have the camcorder repaired free of charge. Best regards, Arpi
Jul 01, 2007 | Canon MV700 Mini DV Digital Camcorder
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
