Question about Refrigerators
Frig has ice build up inside, all over coils and where it drains from freezer-help!! I just defrosted it this morning. Could it be that drain is froze, if so what can I do. And what will happen if the ice stays built up on the coils and where it drains? How bad is all of this for my refrigerater? thank you
  • amylynn0373 Jul 29, 2009
    thank you-there could be a problem with the drain part being clogged with ice, etc. what do you think?
    should i try to clean it out-i already used hair dryer to melt, it helped some. God Bless
  • amylynn0373 Jul 30, 2009
    Thank you again-I did use the hair dryer again inside of frig and freezer-it really seemed to help this time. So, for the time being everything seems pretty normal(very little frost on coils, which could be the humidity) with the frig. I even turned the temp control down and is back to same coldness as before. This is good, but I am still keeping an eye on things for changes, if so I'll let you know more detailed information(model number, etc.) Take care and God Bless.
    Scholar:
  • 86 Answers
Most likely your defrost cycle is not working. That you've to check out the timer the defrost element and the defrost thermostat. Hope this'll help, have a nice day, God Bless
Posted on Jul 29, 2009
  • Dickson LAU Jul 30, 2009
    Can you let me know the name and the model no. of your refrigerator, so we can talk a little bit more in detail. At this moment I can only given you a general idea . Yes as you say the drain may be frozen up and how do you defrost the frozen water in the freezer drain pan and the drain elbow .You have to be sure the drain is clear all the way to the bottom plastic tray. Last time I spend a little bit more time on defrost the frozen elbow by using hot water to melt the ice and using a wet and dry vaccumn to **** out the water , I repeat this until I can let the hot water runing down the drain tubing to the bottom drain pan.then I know I've clean out the whole drain system. I hope this can help . Have a nice day, and God Bless.
Model #970658324 leaking water from the freezer to top shelf of frig once a week probably with defrost cycle. Help!
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Jun 04, 2012 | Kenmore Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Where is the drain hole? The refrigerator is defrosting and the condensation is under the bottom drawers instead of the pan beneath the frig. I can't find the place where the water should be draining...
The drain is in the FREEZER. Frost and ice melts off the evaporator coil during the defrost cycle and collects in a tray directly under the coil. The tray is pitched to the drain tube that runs inside the fridge wall to a pan under the fridge - where the water is evaporated by the heat created by the compressor and the fan that cools the condenser coil.
To see these parts, unplug the fridge. You'll need to remove the inside rear wall of the freezer. That means the freezer needs to emptied, ice maker removed, etc. Chances are that the drain is clogged - most likely with ice. Manually defrost with a hair dryer and use a turkey baster filled with hot water to direct a stream into the drain tube. Resist using tools to chip ice - the components are made with soft metal and if punctured will allow freon gas to escape. You can suffer instant frostbite to exposed skin or blindness if it gets into your eyes. Once water is flowing, consider hanging a piece of copper or aluminum wire from the defrost heater down into the drain tube. Make sure the wire hangs down as far as the ice build up did (2 or 3 inches at most). This will help conduct the heat into the drain tube and prevent it from icing over in the future.
I hope this was helpful. If it was, please rate it "4 thumbs up". Thanks!
Aug 01, 2011 | Whirlpool Refrigerators
Inside bottom of freezer every few days theres about a 1/8 of an inch of ice. Can you help me. I have cleaned out the freezer several times but cannot find the origin of the water. Thank you
The water is from the defrost cycle thawing the evaporator coil.
The defrost drain line in the freezer is frozen over with ice and the defrost water is not draining.
Turn off the power and remove the rear freezer panel and the freezer bottom panel.
Use a hair dryer to defrost the ice at the drain hole in the center of the drain trough underneath the coil in the back of the freezer.
This will take some time to do because the process will be slow.
Jul 31, 2011 | GE GTS12BBPR Top Freezer Refrigerator
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Good afternoon........ I have a top mount frig.. we bought it in 1998. The frig works great..... The only problem we have is water seems to built up on the inside bottom of the frig.... I know it is not...
Hi Dan,
It sounds like you have a defrost drain issue. An annoyance to say the least. To repair you will need to clear the defrost drain as it can get a build up over a few years of use. On a top freezer model you will need to unload the freezer and remove the back panel, be sure the power is disconnected by unplugging the refrigerator.
With the back panel off you will see a set of coils that resemble a radiator in a car, below that coil is a pan that slopes to a hole the size of a dime, you may not be able to see that hole due to the ice build up. Clear the ice with hot water and towels to clean up the mess. Careful not to use anything sharp or damage the coil.
Once the ice is gone use a turkey baster to flush hot water down that dime sized hole until it flows clear, you will know when it is.
Reassemble and enjoy a water free frig.
Apr 18, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from the frig and ice build up inside of frig
Your defrost is not working. First find the defrost timer, make sure it is working. Mark the little dial and wait a half hour or so to see if it moves. If you do have to replace the timer, you may still have to do a manual defrost, the ice in the freezer can take a long time to melt out. If your freezer does not come apart easy, you can turn the timer to the defrost spot(it will click and the compressor will stop) a few times until no more water comes out of the freezer drain tube to the drain pan. You will then feel good air flow out of the freezer fan. If the freezer drain is frozen up, which happens on my fridge it will take all day for it to thaw. That's why I have to take my freezer all apart, a real pain.
Feb 15, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
