Question about Microsoft Xbox 360 Console
Can't connect to xbox live. I use a router and i have pc + xbox connected to it. The internet for the pc works fine but the xbox won't connect to live. Anyone know what the problem can be? Thanks for any answers
  • 59 Answers
The first thing I would do is reboot your router... secondly go into the xbox dashboard network settings and run the network diagnostics. This may help diagnose issue.
Posted on Jul 28, 2009
  • 72 Answers
Troubleshoot this problem on xbox. Sometimes you need to leave the xbox360 until the computer has fully loaded and is connected the the internet. It could be the cable your using may have a faulty conenction.
4 Suggested Answers
  • 4 Answers
SOURCE: xbox 360 elite
hey do u have the rite cables and do u have dsl if u have and alarm hooked 2 the phone line that might be the problem also
Posted on May 25, 2008
SOURCE: When I try to connect to Xbox Live with a router it says DNS fail
U R ***
Posted on Apr 25, 2009
DRAGONF1R3
  • 115 Answers
SOURCE: connect to internet
Okay, so I already wrote a tip about this, so go here:
http://www.fixya.com/support/r3972836-connect_xbox_live_wirelessly
for step by step instructions on how to connect to XBOX LIVE wirelessly. Hope it helps :)
Posted on Jan 25, 2010
I use this router to get internet for live on 2 xbox 360s, it works just fine when i connect a single xbox but when i try to connect to the 2nd one has alot of trouble connecting (i do eventually get the...
Could be a few different problems. One is your internet connection speed. If its below 5Ms I would say you are blowing out your bandwidth and it your ISP can't keep up, thus causing a slow connection or even some time-outs. If you are at or above 5M, check what ports you have your connections in. Some hubs are set specifically to take the ISP in a certain port and have it looped through another port. I'd start there.
Oct 04, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Xbox can't find network on PC.
the other persons tip is trash mines better ;)
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers2_bing.gif info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway2_bing.gif is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address2_bing.gif so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 19, 2009 | Computers & Internet
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
CONNECT XBOX 360 TO COMPUTER
you are only sharing files with your pc to xbox, you cannot connect to the net throught the pc, the xbox has to have connection to a modem/router, or a router itself which is connected to modem.
Aug 21, 2008 | Microsoft Xbox 360 Console
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Connecting to xbox live failing
The xbox live board is down,so if you pass all tests except the xbox live one,this is the problem.I rang them and they said over 50% of users are having this problem.Its because so many people went on it over Christmas and the system got overloaded.They said they're working on it and it should be up and running in a week or two. ~~PS~~ I rang on the 12-1-08 so it should be up by the 20th,its not your fault,the servers down.
Dec 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
146 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
