Question about Lexmark Z2300 InkJet Printer
Paper pulled in skew why
Jams the paper
  • 724 Answers
Poor grade paper wet or damp paper
wet or damp environment
bad roller transport
old and not clean unit
Posted on Jul 28, 2009
Paper jams after pulled in skew
Mine did this ages ago. I found a staple had accidentally fallen into the printer and jammed on one side causing the paper to go in skewed and then jam up. Get a torch and have a really close look inside where the rollers are for staples, paper clips or bits of paper stuck on the rollers.
Aug 28, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
How to correct paper skew?
It sounds like there might be a fragment of paper or other debris in the paper path causing the paper to pull to one side. Try using "Canned Air" to blow out any paper debris - See if that helps.
May 22, 2014 | Marquette Mac 6 Ecg Machine
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
I got a paper jam. I can not get to the paper. I see a small bit a paper but I can not get to it. I can not open the rear access panel. I can not pull the jam from the front. How do I clear the jam out?
I removed the cartridge, pulled out the skewed paper and it ripped leaving a very small piece behind. This continued the notice 'paper jam'. I had to remove the two side springs, remove the two star headed screws nearby the springs and prise up the grill to remove the paper shred. Replace everything and the error message is gone and printer normal.
May 19, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper Jam!
Hello sir; There got to have something on thr paper path check very carefully, especial at the point of the paper skew.
May 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Lexmark x1270 paper jam
hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
Dec 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
Paper feed skews right and jams
Mine is also doing the same thing. Very frustrating!
Jan 02, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark Z2300 InkJet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
