Question about Dometic Rooftop RV Air Conditioner
Is the Air Conditioner our problem?
We have a 2001 32' Coachman w/ a 15000 BTU rooftop air conditioner unit. For the past month, we've been having excessively hot days (100+). For the past week or so, the air conditioner seems to run ok until the hottest part of the day and then the surge protector we have on our RV cuts the power. The RV park has tested the 50 AMP plug & says everything there tests normal. Could it be that our air conditioner needs to be cleaned or serviced rather than there being an electrical problem? I don't know if the coils have ever been cleaned.
Is cleaning the coils really an easy thing to do or should we just call our repairman? I've read a bit & it sounds easy enough. Also, if cleaning is recommended is it adviseable to use the air conditioner coil cleaner foams that I've seen at home repair centers that are used for window units or is it best to just use a gentle stream of water to rinse the coils until the water runs clear?
Thanks so much for any advice you can offer! We love the RV life & learn new things about it every day :-)
    Brigadier General:
  • 4,090 Answers
If the intake vents are occluded in anyway or debris surrounds the coils this will cause the internal temp to rise to critical and trip the power. Unless you are skilled and agile and have a knowledge of how to open the unit I would be saying get a professional to look at it in case it goes further than thye basic problem as a result of overheating several times.
The last thinhg you need is no A/C in hot periods and a few hours shopping whilst it is being looked at by an A/C tech is well worth the visit before it costs more by not diagnosing another problem early
Posted on Jul 28, 2009
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
Sep 03, 2014 | Electrical Supplies
My duro therm 15000 btu air conditioner runs fine until set temp is reached. The unit then starts to cycle on and off about every 2 minutes.
Service your indoor and out door. Due to over dusty, sometimes, this type of malfunction may happen. Thanks.
Oct 16, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
Aug 19, 2011 | Dometic Rooftop RV Air Conditioner
What type freon for 1998 newmar mountainaire 15000 btu ac unit
Early years were R-22 but the best way to double check would be to contact manufacturer with model and serial number for confirmation.
( dometicusa.com ) for dometic products, or ( http://www.rvcomfort.com/rvp/tech_info/manuals.php ) for Coleman.
Aug 10, 2011 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
Mar 11, 2010 | Dometic Rooftop RV Air Conditioner
Btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Mar 29, 2009 | Dometic Rooftop RV Air Conditioner
Duo-them 15000 BTU roof air
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
Aug 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
155 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
