A 5115 total count has cleared, is there any way
The total page count has cleared, is there any way to restore it?
  • 1,326 Answers
Maybe, what kind is it? Why was it cleared? Most likely if it is not a hard counter, you can not make up a counter that works for you.
Posted on Jul 29, 2009
Hp Laserjet P2055d-Page Counts error
are you looking at the pages printed on the toner cart. print out the supplies page.
Jul 28, 2017 | HP Office Equipment & Supplies
I have a code E000013-0001 code showing on Canon 6055i copier
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Apr 24, 2013 | Canon IMAGERUNNER 6570 Copier
Hp 1020 printer total page count information
Hi, what operating system are you using? In Windows XP you can view the page count by doing the following:
- Go to the printer's Properties window (click the Start button, go to the Control Panel and click on Printers and Faxes, right click on the printer and choose Properties).
- On the General tab, click Preferences.
- On the Basics tab, click About.
You can see the page count in the About window, toward the bottom.
For page count or configuration page instructions on other printers and copiers, check out the How to Print Configuration Pages website. Thanks for using FixYa!
Aug 31, 2011 | HP LaserJet 1020 Printer
UPS on battery less than Notification Delay
Not sure exactly what the problem is here without more of a description. The product page for the 5115 UPS is here: http://powerquality.eaton.com/Products-services/Backup-Power-UPS/5115.aspx?cx=3
You can contact Eaton for support:
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Dec 19, 2010 | Powerware 5115 UPS System
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Page count
If you don't have the paper manual, check out the manual on Konica-Minolta's website: DI151 User Manual
From page 4-2 and following of the paper manual or page 48 and following of the PDF document: When 12,345 shows on the Total Count display: <the readout shows:> ct 01 23 45
When 1,234 shows on the PM count display: <the readout shows:> CP 00 12 34
To select a Total Check function: Press and hold the Clear/Stop key for three seconds. The total count will be displayed. Press and hold the Clear/Stop key again for three seconds to display the PM count. Press the Clear/Stop key to return to the previous status mode.
From the way it's written in the manual (I've never seen this machine), it sounds like the readout will pop up
ct
01
23
45
ct
... etc., so you may need to have something to take notes on.
Sep 18, 2008 | Minolta Di151 All-In-One Laser Printer
jasbo
jasbo
