Back to:
Tags:
Oracle 10g Database Standard
Quickbooks
posted by stanie on Nov 22, 2007
When clicking Quickbooks, an Error message is " quickbooks has encountered an error and must shutdown"
Note it may be related to Error 1603. Stan
Comment by stanie, posted on Nov 26, 2007
I cannot open Quickbooks, so I cannot backup data
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
kriadtexas
Rank:Apprentice Apprentice
Rating: 70%, 2 votes
Have you tried reinstalling your Quickbooks? From time to time Quickbooks does have errors related to their updates. The 1st step I would suggest is back up your company data file, and then uninstall, shut down, and then reinstall. Then you can import your data file back into Quickbooks. This should resolve your issue.
Comment by kriadtexas, posted on Nov 26, 2007
What you can do is go to C:\Program Files\Intuit (you may or may not have another sub-folder called Quickbooks or QuickbooksXXXX) You can find your data file in here. It will be what ever you named your data file when you set it up, for instance, mine is Kriad Computers.QBW. You will want to copy that file along with the file [Your File Name].QBW.TLG (i.e., mine are Kriad Computers.QBW and Kriad Computers.QBW.TLG). Now you can safely uninstall Quickbooks, and reinstall it. After you have reinstalled, then you can take and copy those 2 files back into the same directory where you took them out of.
Hope that helps, and let me know if there is anything else I can assist with.
Thanks,
Chad K.
Rating Locked! (?) stanie has rated this solution as Not Rated
Thank You!
Was the solution helpful?
Show your appreciation by commenting on quickbooks:
I don't want to Accept this solution
Can you Help with these Business and Productivity Software problems?
How to add on Excel?
Oracle 10g Database Standard (ODBSEONUPP0)
This Oracle error keeps occurring Oracle Error :...
I get this sql error every time I try to connect to an...
I have an Oracle date problem I want to use in the where...
How to writ the code in visual basic to create database in...
Loading problems.
Repair Service
Find Business and Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
