Question about Garden
Fuel line routing for mcculloch 3303ax trimmer
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Poulan sm132 fuel line routing
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Posted on Aug 27, 2009
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
rycgl
  • 1545 Answers
SOURCE: need fuel line routing on 32cc gas trimmer
This is an ongoing issue for users, and rightfully so .On your machine.. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Sep 03, 2010
Hi,what size is the fuel line for a McCulloch MT-270I TRIMMER?
The part list only specify a part number and not size. I would recommend removing the fuel tank and carry it in to obtain the proper fiction fit of the fuel line. It is probably 3/16 od but not 100% sure.
Jan 21, 2015 | Garden
What else should i try
Sounds like the check valve in the primer base is stuck/clogged/damaged, assuming the fuel lines and fuel filter are intact and not clogged, It will have to be replaced.
Jul 25, 2014 | McCulloch 2816 Edge Trimmer 28cc
Illustrated fuel lines on husquavarna trimmer
What model are we talking about here, i can describe the routing once i know what model you are working on.
May 02, 2012 | McCulloch 26cc Gas Blower Mcb3208
Fuel line diameter mcculloch trimmer eager beaver 2
According to Randy Duncan Ebay site(Randy's Engine Repair) the fuel line is 3/32" inner diameter and 3/16" outer diameter for the non-primer bulb side of things for a McCulloch chain saw. It is a common size, apparently, but is not listed in the User manual as such.
Apr 30, 2012 | Garden
How do the fuel lines go & which one does the filter go on , on a McCulloch MAC3200 , mod.#22600032-69
Hi krangel123...
Check out the routing of the fuel lines in the drawing below
Please take time to rate me thumbs up
Sep 18, 2011 | McCulloch Garden
Mcculloch hedge trimmer when I put it on its side to fill it up petrol pours from the opposite side does the tank have a breather
Tank should not have a breather, the fuel cap does that function. Check your fuel lines and where they penetrate the tank. Today's fuel will eat the fuel line over time and there is also dry rot. The fuel lines on these need to be monitored over time to ensure continued safe operation of small engine equipment.
I hope this is helpful for you.
Aug 26, 2011 | McCulloch Garden
What fuel ratio do I mix my two cycle oil; for the McCullock 3303ax??? 50:1 (2.6/gal) or what. I do not owners manual. thanks It is a weed trimmer.
Check on the fuel cap or near the fuel cap. Some brands have it there, if it says at all on the equipment.
Aug 02, 2011 | Garden
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Aug 16, 2009 | Poulan Garden
McCulloch MAC2815 string trimmer fuelline connections
you have 50/50 chance of getting right you wont hurt if wrong try till unit works!!! :)
Jul 06, 2009 | Garden
Garden Logo
602 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
